22-05-17, 08:11 PM
(This post was last modified: 22-05-17, 08:14 PM by vdbergroel.)
[size=1em]Hi all!
[/size][color=rgb(34, 34, 34)]
Since a short while I'm also a proud owner of a Fazer 600 from 2003 with about 25.000 miles on the counter. I bought it from someone who didn't run it for a year or two and during the test ride I only had some issues with the gas not going down the moment I let go of the throttle. Easy I thought, man I was so wrong.
[/color][color=rgb(34, 34, 34)]
On my way home I noticed (when it was warm) it would make a loud pumping noise when in neutral. Holding the clutch would make it stop. The day thereafter the fun started when I tried to start it: it ran instantly and then died within a split second. Furthermore it wouldn't show any sign of life afterwards. After waiting a long time and trying to start again it would again show some life and die as soon as it started.
What did I do then:
[/color][color=rgb(34, 34, 34)]-I cleaned the airfilter
[/color][color=rgb(34, 34, 34)]-changed oil + filter
[/color][color=rgb(34, 34, 34)]-put in new sparkplugs (old ones had the proper coffee brown color)
[/color][color=rgb(34, 34, 34)]-tanked 'premium' gas and added a bottle of carb cleaner[/color]
[size=1em]Afterwards I started it and when it was on for a split second I gave a lot of gas and it stayed alive. Keeping it at 2-3000 rpm it became warm and would run perfect, also in neutral (noise was still there). I drove 100km and put it away. The day after again the issue occurred, I tried to let it start normally without giving a lot of gas straightaway - and failing to do so would also mean it wouldn't give any sign of life during any attempts thereafter.[/size]
So I went on:
-cleaned the carbs (some dirt, not too much)
[color=rgb(34, 34, 34)]-replaced the gas filter
[/color][color=rgb(34, 34, 34)]-reset the cam chain tensioner
Unfortunately that did not change anything.
[/color][color=rgb(34, 34, 34)]So now every time I try to start it, it starts perfectly, moving up to high (3000-4000) rpm and then dropping fast to 0. Then when I try to start again (with or without gas, with or without choke) it doesn’t start and it sounds as if it is more and more difficult to get around every time I try it. When I put it away for an hour or two the story starts over again.
Now my question is, any of you got any tips how to pull my fazer out of the rabit hole for good? Thanks![/color]
What did I do then:
So I went on:
Ready to rumble
