Needle roller bearing help required
Pulled the swingarm from the ZZR and surprise surprise the needle rollers are shot
A kit is about £50 inc new seals etc but the seals are servicable so really just need a set of bearings
Anyone out there used non stock bearings and if so how did you get on and where did you buy them from (I know its not the same bike)
Won't you bugger the seals taking them out anyway. The best way to buy bearings is from somewhere like bearings r us or similar online bearing suppliersthey will sell the seals too. Look for the designation on the edge of the bearings and the seals will have a designation on them. I replaced mine on my old GPz750 for a fraction of the price Kawasaki wanted for them. Wheel bearings etc. are also much cheaper bought this way. If you struggle to match them up, just give 'em a call. :thumbup
(22-04-17, 05:11 PM)vinnyb link Wrote: Won't you bugger the seals taking them out anyway. The best way to buy bearings is from somewhere like bearings r us or similar online bearing suppliersthey will sell the seals too. Look for the designation on the edge of the bearings and the seals will have a designation on them. I replaced mine on my old GPz750 for a fraction of the price Kawasaki wanted for them. Wheel bearings etc. are also much cheaper bought this way. If you struggle to match them up, just give 'em a call. :thumbup
You can pop most seals out using a large flat bladed screwdriver as a lever, dont foc about trying to pry them out, a quick bang on the handle usually gets them out with no damage.
Seems I've got lucky with two of the three bearings, and have found one for £13. Will need to also replace the radial bearing but its only a couple of quid.
I know I should probably change them all but its not for NASA
Don't forget the Moly Disulphide grease
(22-04-17, 05:38 PM)vinnyb link Wrote: Don't forget the Moly Disulphide grease
Have already packed the remaining bearings out with molly after a good clean with carb cleaner to remove all the dried up crap in there. Focin previous needs a grease gun ramming up his ass, they put nipples on there for a reason..................Twat
As for the MOT tester, he needs his license taking off him
