center stand/after market end can
Hi all,  to those of you that have fitted after market end cans, which cans allow the center stand to be retained. Cheers.
I'd say most of em, but I could be wrong. Wink
I've not heard of any aftermarket cans for the Gen1 that require the removal of the centre stand, but if you wanted to be sure you could contact the manufacturer or post on here to see if anyone has the can you are thinking of.
as long as your fitting a fzs1000 link pipe then most end cans would fit, the fzs1000 is 60mm at the collector, most end cans are 52mm.............
the only issue you will have really with end cans not fitting is if you try and fit a stupidly short one that doesn't reach to the pillion hanger fixing point
Viper, Art & Fuel that I know of for sure!
