07-04-17, 04:48 PM
2002 fzs 600
I came to change my rear pads, after the brake had been getting progressively worse. Ive noticed that the pistons are pretty far out and have a lot of corrosion around the rim. Ive taken ther calliper off, split it, got it in the vice but it wont budge with anything i can get on it, short of welding somthing to it.
I gave up for the day, and decided to look for a used caliper.
theres only 1 that i can find on ebay, its £90 and its in spain.......
so, i may have to put new pistons in this, but as the pistons are corroded-theres traces of corroded rubber, presumably a seal where it come out too far, i'm worried that bthe bore may be knackered too.
Is there any other callipers that people have used on the rear, as these seem pretty scarce, and expensive for what they are......
if not, has anybody had any dealings with re doing the pistons? ive seen stainless ones on wemoto, but its going to be about £70 for those......
An expensive day, as i probably need to replace the disc as well.....
Thanks in advance for your help
