06-04-17, 07:34 PM
Hello all, it's been awhile, hope you're all well?
OK to the point.
2004 grey import, 30K, full service, good oil used always, new EBC clutch pads, new clutch cable, all set correctly but for the life of me I can't get rid of the notchy gearbox, as some have mentioned in their own posts it seems to be 1st and 2nd gear, doesn't matter if the bikes hot or cold at times it's like a spoon in porridge trying to find first :'(
I had a 2001 Fazer thou previously and that was silky smooth but it had a 1/3 of the miles on the clock. Yesterday on the run back from the north it was fine and even changed up with no clutch but then as soon as I was back to having to go down to first and second (pulling upto junctions or lights) the notchiness and sloppy feel started again.
HELP!!! (is this normal? is it down to some bikes? or is the box on it's way out???)
thanks in advance
OK to the point.
thanks in advance
I like bikes....ALOT!!
![[Image: 125377.png]](http://mefi.us/images/fuelly/smallsig-uk/125377.png)
