Need new front brale discs? Suggestions?
As title, i see alot of aftermarket sets on Ebay etc? Not many official yamaha ? Anyone have a good set they are breaking? Are aftermarket sets garbage?
Mot is coming up so gota get this sorted fairly fast Smile
THANks
Toby
I guess what i mean is are EBC aftermarket discs or similar ok?
For me EBC is a top good quality brand making braking products for wide range of vehicles and applications. There well known and decent quality brand also producing a lot for motorsport aplications so should be no problems using them or other top brands alike. Used ebc products in past for off road bike and car and can't complain with anything I've used from them.
Only thing with discs and pads is making sure to use same spec/quality I.e. Not using cheap cheap, crappy discs and then using a higher grade/spec/quality set of pads.
A lot of folk go for cheep crap discs due to the fact they are expensive for a good set and then get good quality and high spec pads due being cheaper and thinking that's alright.
Crap quality discs/lesser brands save money with the grade of steel they use and then the hardening/surface treating processes they go through. Meaning in some cases the pads actually eat through your discs!
In my opinion brakes should never be skimpt out on!
Anyway just my 2 pence about what I've used and found in the past. I'm sure some might agree and no doubt others will disagree but again it's just my opinion thrown in to try help yourself out!
Hope it helps you out in some way!??
My bike doesn't need brakes done at the moment but when the time come I spied these which I quite fancy. Haven't used these specifically before but will deffo be reviewing them on here once fitted when the time comes
Fronts:  Discs----  https://www.sportsbikeshop.co.uk/motorcy...prod/50671
            [size=78%]Pads----  https://www.sportsbikeshop.co.uk/motorcy...prod/47079[/size]
Rear:    Disc---- https://www.sportsbikeshop.co.uk/motorcy...prod/50673
            [/size][size=78%]Pads---- https://www.sportsbikeshop.co.uk/motorcy...prod/52400 [/size]
Again just my preference, the products and where you by from are up to you obviously!
Dunno what the front EBC discs are like, but my bike ate a rear one in about 10 months.
What pads did you have in darris? What mileage did you get out of them?
I personally have no problems with ebc brakes used on many cars, quads and crossers and been happy with them but hey that's me! Everyone will have different circumstances and views!
(15-03-17, 02:42 PM)SutherlandFZS600 link Wrote: What pads did you have in darris? What mileage did you get out of them?
I use the rear quite a bit as a commuter, but i do low mileage and nothing was binding, so regardless of whatever pads i had in, 10 months is still disappointing.
Think it was a ProLite EBC disc.
(15-03-17, 02:26 PM)darrsi link Wrote: Dunno what the front EBC discs are like, but my bike ate a rear one in about 10 months.
Blimey! Was it made from aluminium? I'd expect at least a decade's use from a rear disc.
I used to get through a set of OEM front discs every 40,000 miles and switched to using second-hand ones off ebay to save money for many years. I bought some EBC Prolites a few years back and they're holding up well... must have around 40k on them now and there's still plenty of life left.
For some reason EBC included sintered pads in the kit. They proved to be a terrible match: grabby and if wet would bond to the disc while parked overnight. I switched to their organic pads and have powerful, progressive braking with no nasty surprises when you try to move the bike in the morning.
(15-03-17, 06:18 PM)Fazerider link Wrote: [quote author=darrsi link=topic=22120.msg255611#msg255611 date=1489584402]
In fairness i did have front juddering issues at the time so was probably using the rear more than normal.
Apparently it lasted about 14 months, not 10.
Hi
I have these http://www.ebay.co.uk/itm/Yamaha-FZS600-...Sw4SlV7qH0
[Image: 151244.png]
Four Wheels Moves The Body... Two Wheels Moves The Soul
(16-03-17, 09:01 AM)Tefer link Wrote: Hi
I'm sure they're totally fine, but whoever designed the drawing to advertise them needs to be sent to the naughty corner!
Will later model discs fit a 1998/99 for example 2001-2003 ?
(16-03-17, 11:21 AM)Tubz1983 link Wrote: Will later model discs fit a 1998/99 for example 2001-2003 ?
Yep
EBC aren't what they used to be and I mean since about 2000 :eek  they were taken over by a US company.
Their discs in my opinion are crap they're are cheaper for a reason, either go OE the best option often cheaper or not a lot in it you'd me amazed, or Brembo, Galfer  avoid Armstrong and Viper.
Later
