Drained the old oil today, however the filter does not want to budge AT ALL. Any tips? How important is.changing the filter?
Ive put some wd40 round tye edges to see if that free anything up
Manual says 1 filter change for every 2 oil changes. But I change it everytime.
It can be an foccer to get off anyway, even if only put on finger tight with a lube oring. I give mine a good squirt of penetrating fluid with a wiggle the day before trying to get it off. One you break the rubber seal all round it usually comes off quite easily.
-suck-squeeze-bang-blow-
Always resorted to using an oil filter chain wrench. They're only a few quid but an invaluable bit of kit.
When you eventually get the filter off, you need to smear the rubber seal with oil on the new one then just do it up by hand as much as you can, they really don't need to be wrenched on tightly.
And yeah, they do an important job so they do need changing, especially if you don't know when it was last done.
You can get away with replacing it every 2 oil changes but to be honest because they're so cheap you may as well do it each time.
Hmmm i did see the chain wrenches.... Il go back to the garage in a bit and see if i can budge it
(19-02-17, 01:28 PM)Tubz1983 link Wrote: Hmmm i did see the chain wrenches.... Il go back to the garage in a bit and see if i can budge it
I use a oil filter spanner that attaches to a socket set like this (random internet grab for the picture)
https://www.motorcycleparts-hornig.com/B...74-mm.html
That looks like a blood good idea actually!
BIG screwdriver smashed through the filter and give it some beans turning wise.....works every time :-)
Smashed through the top end of it? Sideways on?
Sideways so it acts as a lever to rotate it, that's the way I've had to do it!
This is as young as you're ever going to be!
(19-02-17, 08:08 PM)Tubz1983 link Wrote: That looks like a blood good idea actually!
You have to fiddle it from the side behind the downpipes and slide it on then with a short extension on your socket poke that through the middle of the pipes and loosen only then draw out the socket and take the wrench off the filter and carry on undoing with your hands / fingertips ------------ expect to spill it all over your pipes underneath ---- and then the floor.
Sometimes a screwdriver driven through the side works..and sometimes it rips the shit out of the filter. Marigold gloves are worth a go if the filter is cleaned first - seriously.
try a chain wrench before a screwdriver.
(19-02-17, 11:58 PM)His Dudeness link Wrote: try a chain wrench before a screwdriver.
I deliberately never mentioned the screwdriver trick simply because of the carnage and mess it can cause if it goes wrong. :lol
I've got one of those rubber strap thingies (no space for it on this bike), one of those cup things that fazersharp mentioned but my favourite is this
https://www.machinemart.co.uk/p/clarke-c...lter-wre/. Works like a charm.
Malc
Old enough to know better.
(20-02-17, 06:27 PM)Jules-C link Wrote: [quote author=Graham53 link=topic=21877.msg253100#msg253100 date=1487545680]
And if the screwdriver doesn't work cos oil filters are only made of thin metal .. you're focced
Once had the screwdriver trick not work after chain and belt wrenches just crushed the casing. If you are VERY careful you can cut the filter baseplate into pieces without damaging the mating surface on the crankcase but it's not something I would recommend.
Still had a job getting the final piece of the baseplate off the thread. I think the thread had been damaged by an earlier attempt to screwdriver it off.
Normally use K&N filters now with nice 17mm nut on them
Used to think the K&N oil filters were good until i found that the nut part was covered in plastic and didn't fit any size socket.
Back to the trusted and reliable chain wrench again.
