sprocket options
some of us here may wish to change sprockets for many reason
mpg on tour = -teeth on rear (+front)
acceleration =  +teeth on rear (-front)
stunters = crazy+ teeth on the rear
of course teeth on front is 1 on front equivalent to 3 on arse
anyone know of suppliers for sprockets for fzs6 that can create a a stunt bike
my fzs600 needs a new sprocket and chain set so might as as well stunt her.
motovlog meetup/rally coming soon
These guys out in Lincoln do a lot of non standard stuff fella, might be worth a try.
http://www.bandcexpress.co.uk/
had a float about and found a few options for undrilled discs (centre bore only) which are always an option
ebay has +/-  1+2 so there are options there for easy wheelie and ridable
- just got used to the 7k flat spot (2 power zones) switched to tesco high octane fuel which was a mistake
  (dies early at high rpm)  [/size][size=78%]switching back to normal octane asap[/size]
going to try hi oc and hot plugs to see if it works better
but i dont want hi oc all the time
