2001 hugger?
can any of you learned gentlemen tell if this will fit a 2001 fzs600?
ta!
[Image: IMG_20170125_1648491_zpsjp7rj4dt.jpg]
[Image: IMG_20170125_1648561_zps3eyqmvxz.jpg]
[Image: IMG_20170125_1649101_zps6y70lzsy.jpg]
no--as the hugger for the 2001 model just bolts on where the chain guard is and also where back brake pipe containment loop is bolted to the swing arm with 2 bolts/set screws only---sorry.
that's fine. i assume it's for the earlier model then?
