Another year another MOT. Passed but with 4 advisory notes
1: Front brake pads near minimum limit - new pads have been sitting in the garage but not fitted for the last year so no argument there
3/4: Rear shock misting/reduced damping a bit disappointed since the Hagon has only done about 15,000 miles but at least it's rebuildable.
but number 2: Brake lever is short but brake can still be readily applied. Since it is working without problem why is it an advisory? Not really bothered but seems odd to put it in as advisory
And why not put an advisory for short clutch lever under section 6.2.1g
g. a clutch lever so damaged, positioned, bent or shortened that it cannot be readily operated
its an advisory. You choose whether to take any notice or not.
Does your brake lever have a ball on the end? if not then that's probably why advisory,the ball is there to stop your fingers from sliding off the end.
are they the shorty Chinese pazzo copies? as i've always passed when using them before.
my momma always says, stupid is as stupid does.
that's all i gotta say about that
Yeah the Chinese copy ones. Passed last year with them on at the same place with no advisories. Tester obviously trying to get his score of advisories up to show he's doing a proper job!
Same test station but was it same tester?
You could always ask the tester why he put an advisory on for the short levers.
I had some Titax short levers fitted on my FZ1s but never felt comfortable with them, I have wide hands with short fingers and standard levers felt much better for me.
(11-01-17, 02:45 PM)bandit link Wrote: Does your brake lever have a ball on the end? if not then that's probably why advisory,the ball is there to stop your fingers from sliding off the end.
I always thought the ball was a safety feature added to stop the leaver from stabbing you in an off
Mine nearly got failed last year for having ASV short levers on.
When I asked why the bloke said short levers are a fail, so I asked him to show me where this was written to which he replied I'll pass it this time.
How to lose a customer in one easy lesson, three car's and two bike's now going elsewhere.
Might be a silly question but what are the benefits of short levers? Why do people fit them?
(12-01-17, 02:31 PM)acid drop link Wrote: [quote author=His Dudeness link=topic=21652.msg249724#msg249724 date=1484216951]
Blinging the bike up maybe.
On a bicycle, I prefer short levers: using only max. 2 fingers on the levers, with short ones, I can pull them all the way to the bars, without them hitting my other fingers. On a motorcycle - never tried short ones, but if it's a similar effect, then I'm a fan!
(12-01-17, 02:31 PM)acid drop link Wrote: Blinging the bike up maybe.
:agree
But also to reduce the braking capacity as you cant get enough fingers on the lever to apply full pressure (even though others will disagree).
that said, only two fingers (or one strong one) needed to lock the front wheel on an FZS600 with proper working brakes.
(12-01-17, 02:35 PM)BBROWN1664 link Wrote: [quote author=acid drop link=topic=21652.msg249737#msg249737 date=1484227908]
:agree
Yes exactly and the leaver shouldn't get anywhere near the other fingers unless you got no brake fluid in there
(12-01-17, 11:29 AM)His Dudeness link Wrote: Might be a silly question but what are the benefits of short levers? Why do people fit them?
i got little hands so prefer shorty levers as less span
:agree
Same goes for bicycles. I still prefer to have more travel room for tha levers.
As for clutch - there I'd definitely like to have a shorter lever.
