fork emulators
hi can anyone point me in the right direction for these  you can get pd ones but cant get the size to order tried many searches
Wemoto do YSS ones for the 600  Smile
http://www.wemoto.com/bikes/yamaha/fzs_6...rk_valves/
out of stock
If memory serves, the SV650 uses the same ones.
http://www.ebay.co.uk/itm/172385678128
I'm sure there will be more stock in the New Year, Wemoto are usually really good  Smile
cheers guys
41mm emulators are listed on some sites for Harley Davidsons and are the same.  Don't just look for Fazer ones
so basically any emulators that are for 41 mm forks will do ?  the vale size varies for 41mm  fork betweeen 31 and 33.5 ??? you  are meant to measure either the spring diameter or the damper rod  http://www.yssusa.com/products_PDValveList.html
