had a bit of a clear out some fazer 600 5dm parts
front+rear wheels powdered coated in gold a few marks but in good condition fitted with bridgestone battlax bt014 tyres 110/70/17 160/60/17 about 5mm+tread no disc but rear fitted with good sprocket and centre hub removed from 1999 12000 mile fazer £125 SOLD
rear tyre bridgestone battlax bt021 160/60/17 4mm+ tread £35
lower fork tube a few marks £29.95
rear disc little to no wear £24.95 SOLD
fork internals spings+washers fork tops etc etc removed dut to bent forks milage 4800 £29.95 SOLD
carbs removed from a 4800 mile fazer running perfectly sat in storage 3 years might a strip+clean £39.95 SOLD
standard end can perfect condition £29.95 SOLD
rear brake caliper+master cylinder+foot hanger+brake switch complete unit 1 piston sticking in caliper sat on shelf 3 years £41.95 SOLD
swinging arm a few marks £25
front brake calipers+master cylinder+hoses complete unit in working condition no brake pads £69.95 SOLD
starter solenoid £14.95
cdi unit £34.95
regulator £19.95
rad fan £17.95
fuel pump £17.95
thermostat houseing £17.95
coil+leads+plug caps 1+4 £14.95 SOLD
coil+leads+plug caps 2+3 £14.95 SOLD
n/s switch gear £17.95
o/s switch gear £17.95
wireing loom+fuesbox+3 relays £39.95
rear suspension linkage £17.95 SOLD
clutch lever+switch+mount £14.95
rear grab rail silver a few scratchs £14.95 SOLD
rear shocker standard £29.95SOLD
fuel gauge sender unit £17.95
n/s rear foot peg+hanger £14.95
inner fairing mirror support brackets x2 £19.95
rear light+bracket £14.95
side stand switch £14.95
rear caliper mount bracket £14.95
coolant header bottle £14.95
plastic airbox covers x2 £14.95
starter motor £24.95
small engine cover a few scratch s £14.95 SOLD
generator+cover good condition £29.95 SOLD
clutch engine cover good condition £21.95
water pump £24.95
cam cover end caps x4 a few scratchs £14.95 SOLD
uk postage is included in the prices pic's available just ask and i will sort some out.
cdi unit £34.95
regulator £19.95
rad fan £17.95
fuel pump £17.95
water pump £24.95
