pipercross airfilter cleaning
as above do you guys with this filter use the pipercross cleaning additive c9003 or is there an alternative?
Blimey,is it dirty already?.
yer filthy and looks abit burnt from blow-backs Ive had
Blow backs, you can handle, it's the follow throughs that get messy.
if its foam,just get the correct cleaning +re-oiling kit for around £15.i had trouble with a pipercross foam filter albeit on a ducati,when they were dry the would cause the bike to miss fire over 70mph,once cleaned and oiled they worked perfectly.in fact i prefer them to k&n filters. just far simpler and do just a good as job
I think I was using the choke to much which caused the filter to get wet I think. I've ordered the cleaning now so hopefully will sort it.
