Tail Tidy
Has anyone tried to fit an FZ1 tail tidy to a Gen1 ?
FZS 1000 Gen1 (2003)
Tiger 900 GT Pro (2020)
I would guess probably not Smile
why would you want to? the rear lights are built in and changing the indicators is easy, you only need somewhere to mount the number plate.
you can get an undertray of cut down the original
(22-08-16, 11:00 AM)Tmation link Wrote: why would you want to?
To tidy the tail?
Yes, I did it but you need to change the entire undertray. You will have to cut the original undertray down near the battery so that you keep the original battery box but you will have to measure it as where you cut it cut depends on which make of undertray you buy.
If you decide on an undertray I'd recommend the Ermax.Did mine earlier in the year, quite straight forward.
