FZR1000 fork swap
I can't find anything in the archives so don't know if this means I'm not looking right or if it can't be done / isn't worth doing?
I'm going to upgrade my 2000 FZS 600 forks. Following Falcon's writeup I decided that I kinda want to avoid the R6 / R1 route as the forks are shorter. (Yes, I get that this improves geometry and turn-in but I want to keep this as my daily commuter and avoid buggering my back in low-speed traffic jams). And here in NZ with a tiny population of 4.5 million they're hard / expensive to get hold of.
So I'm looking at alternative options. I hear that the FZR1000 forks are longer than the R1 / R6. Does anyone know if these are a simple upgrade for the FZS 600? And are they any better than the stock FZS 600? (Bearing in mind they only have pre-load adjustability).
I can get a set of these cheap. Otherwise, if I have to spend big $$$ then it's back to considering a complete front-end from a totally different bike with bearings to fit the stem.
cheers for the advice.
not easily doable they wont fit the yolks you will needs swop wheels and spindles ext meaning ull have to sort a new speedo sensor out ext basicly would need a hole front end swop and tbf iv had the fzr exup ru as my last bike and i prefer the fzs forks nice and light ext the ru only have pre-load adjust-ability. in summary its alot of hassle for very i any gain.
Good sets of FZR1000-RU forks are normally like rocking horse poop. Sometimes its easier to buy the whole bike and break it up to get a set.
thanks gents. That's the end of that silly idea Smile  Soon to be replaced by another - watch this space!!!
