2006 on FZ1 Gauge wiring question
Anybody have a picture of the gauge wiring loom, basically after how many wires connect to the gauges, colours and if know, which wires do what?
Also, does the speedo sensor wire connect straight to the clock sub loom or main wiring loom?
Rough dimensions of the gauge, width length, and depth?
Thanks
Here you go.
There is no speedo signal at the clocks, it's a pure digital bus (ECU k-line). But you can tap the speedo signal directly at the sensor. From there it goes to the ECU (main loom).
.jpg   FZ1 cluster signals small.jpg (Size: 39.82 KB / Downloads: 18)
