Tightening front sprocket (no torque wrench)
As title says, I'm swapping out the front sprocket (again), no torque wrench, is this sensible/OK to do? I have a long arm for my standard wrench.
Toby
Is a bit chancy, you'll either go under which could cause the nut eventually come loose, or go over and mess up the thread.
If the thread was good i would've said it'd be okay but because of the known sprocket nut issues if i were you i'd try and borrow a torque wrench from someone.
With the new 12mm nut it's meant to be 90Nm, although i did mine to 80Nm, as a few others have as well.
Why not ask if a local foccer can lend you one? Where in the world is you?
-suck-squeeze-bang-blow-
http://www.halfords.com/workshop-tools/t...-5-83lb-ft
Wink
I live in Cambridge Bretty
On a budget, these beam style torque wrenches are good for £12.00 delivered  http://www.ebay.co.uk/itm/DRAPER-1-2-SQU...1468687788
They're not as convenient to use as a click-style wrench (you have to get your head level with the arrow when tightening, and make sure the needle is pointing to zero every time you measure something) but mine is as accurate as my Teng (and the Sealey I had before it).  Just don't confuse ft-lb for NM!
[Image: 420174.png]
You don't need a torque wrench. Just ultimate it until you fart and bend the tab washer over.  It won't come loose.
(14-07-16, 11:30 PM)Megawatt link Wrote: You don't need a torque wrench. Just ultimate it until you fart and bend the tab washer over.  It won't come loose.
Think you're totally missing the point here, there are very well known thread issues with the front sprocket nut / shaft.
You go too heavy on that with an extended wrench and there's a small chance you could create a world of pain for yourself.
I just don't see the point in taking that gamble.
Get yourself a torque wrench, they dont have to be expensive here is a discussion on the subject here that you may find useful in your choice  http://foc-u.co.uk/index.php/topic,11878.25.html
If you dont want to buy a torque wrench ( I wouldnt be without mine!) why not tighten up so far & ask a local garage mechanic (car or bike) to torque it up to recommended value?
If you are willing to do certain jobs on a bike or car then a torque wrench should really be part of your tool kit anyway.
It's not like they're even that expensive to buy, it's just that sometimes things need to be done properly, and because of the front sprocket nut issue this is one of those times.  Confusedmash
Having missed the point of a torque wrench and after 40 years working on bikes, I don't understand how the nut can unscrew itself after you've engaged the locking washer on the splines and bent a tab over???? Please explain?
(16-07-16, 06:18 PM)Megawatt link Wrote: Having missed the point of a torque wrench and after 40 years working on bikes, I don't understand how the nut can unscrew itself after you've engaged the locking washer on the splines and bent a tab over???? Please explain?
Fill yer boots.......
http://foc-u.co.uk/index.php/topic,92.ms...#msg141080
I asked you to explain as you're the expert.
(16-07-16, 08:48 PM)Megawatt link Wrote: I asked you to explain as you're the expert.
Try reading my earlier posts and i think you'll find i did.
As i said before, you're missing the point.
I'm bagging a front row seat for this one  :photo
Its true it falls off -- but not on a 98  Wink
(16-07-16, 11:56 PM)fazersharp link Wrote: Its true it falls off -- but not on a 98  Wink
I was waiting for you  :lol
You can lead a horse to water...............! :eek :lol
I was great believer in torque wrenches. Until all my 4 brand new not cheap calibration certificated torque wrenches just stopped working and I have focced up few bolts.
INB4 I was pampering them, never dropped or used them to untighten, kept them untighten too.
Now I just use my hands.Still alive. Make of that what you want.
FYI never seen in any garage that I has been, mechanics to use torque wrenches for high torque bolts like say swingarm bolts. Only for precision low torque like for engine heads.
[Image: 606131.png]
