Coolant drain plug
I am going to flush the coolant on my FZS600 today..
which one is the drain plug? is it the top one? Haynes does not show a pic
[Image: 1F5F14BC-1002-4DBB-B564-3CAAF998B19C_zps8qkhom3k.jpg]
Here you go.....
the image of the little funnel under the drain plug makes me laugh, mine shot out and hit the garage wall when I did it!
[Image: 420174.png]
(08-07-16, 02:34 PM)Adam2201 link Wrote: the image of the little funnel under the drain plug makes me laugh, mine shot out and hit the garage wall when I did it!
A-LA-THIS
[Image: index.php?action=dlattach;topic=10671.0;...8818;image]
[Image: index.php?action=dlattach;topic=10671.0;...8814;image]
See here for info on the subject http://foc-u.co.uk/index.php/topic,10671.25.html
Many thanks...
All drained and put a bottle of Radflush through it, running nice and clean now.
Next job is to drain and flush the expansion bottle. It is not easiest to get to, w[size=78%]hat is the best way to flush it through? [/size]
(08-07-16, 03:30 PM)Adscan link Wrote: Many thanks...
I've never bothered personally, there's not enough in it to worry about, and once the bike gets warm it'll circulate back in to the system.
Me being me - and all that, I empted mine with a bit of tube and a 50mm syringe.
One should never be without a bit of tube and a syringe  :eek
I managed to suck it all out in the end. I have filled up with the new coolant and currently trying to get all the air out the system.
(08-07-16, 06:48 PM)Adscan link Wrote: I managed to suck it all out in the end. I have filled up with the new coolant and currently trying to get all the air out the system.
If you pour it in slowly enough you shouldn't get any air, other than that let it tick over without the thermostat cap on.
You can even give it a gentle bit of throttle to let any bubbles escape, just don't give it a handful or you'll be wearing it.  :lol
All done now.. hopefully i got all the air out.
[Image: 6fc99e3799229757afaadbe0c83c42e9.jpg] Haynes does have a pic,  22.2a
Sent from my GT-I9300 using Tapatalk
Set Fazer's to stun
