Faulty speedo
So the last time I got my front tyre changed, a dealer broke off the speedo drive cog. I recently put a new one in, thinking the speedo would be working now. It's better but still drops to zero very often.
Recently I saw the speedo jump whilst stationary, so it appears I have an electrical problem with the wire as well.
Presumably I just follow the wire and look for where it is damaged and then solder if necessary and put some heat shrink over it?
Has anyone else had this problem?
Speedo or rev counter jumping?
Speedo not rev counter. It's not trying to send me a message!
Had a similar problem with mine. Only had the bike a couple of weeks and while riding the speedo dropped to zero and the Rev counter worked intermittently. Turned out the plank who had it before me had put front pads in. When he removed the calliper he routed the speedo cable incorrectly and it was rubbing on the disc. It had snagged and ripped the wires out the drive. So this sounds extremely similar. Just look for any damage on the wire. It runs up underneath the tank into a loom. I replaced the full drive and cable and it fixed it. Although I payed £70. Hope this helps
If the cable hasn't been routed properly the disc can wear through the insulation on the wires.  Route it correctly and heat shrink or just insulating tape should fix it
What they said
Some say...
I had very similar issues, but before it dropped to zero the needle starts jumping to crazy speeds, according to the Speedo I was going round a roundabout at 145mph but then it would drop to slower and slower indicated speeds untill nothing. It sometimes go's up when I slow down, I've checked all connections, wiring and sensor, can't find any problems. Seems to have stopped doing it now but have become very good at judging speed from the rev counter, if that plays up I'm buggered.
If anyone finds a solution I'd be right interested.
There ain't arf been some clever bastards
Check all the wiring that leads from the back of the clocks to the sensor on the front wheel as thare might be a break in one of the 3 wires, this does mean you will have to cut open the "protective tubing" to view clearly all of the wires. Once checked and repair fixed (if there is damage) re cover the wires with at least 3 layers of insolation tape as to be honest that will be more protective than that tubing they use any way.
had to do this to my bike.
RIP my beautiful red beast 1999 to 2017 ???
The symptoms are definitely what you get when the cable rubs on the brake disk and it starts slicing into the wires. It seems that when the front wheel or brake caliper is removed and replaced it's very easy to miss something that holds the cable away from the disk; I now have mine routed round the outside of the caliper to be on the safe side, since finding replacements for the cable is a bit of a mare.
So I just took the whole cable out from the wiring box under the tank, there are no cuts in the wire; to be sure I triple span round it with insulation tape, connection on both ends are clean, I don't have a multimeter to check how the connection really is though.
I replaced the front wheel a couple of days ago, my replacement ceramic piece is in there fine, the two lugs have not broken off.
Does anyone have any more ideas?  :'(
(12-07-16, 08:36 AM)Fazer99 link Wrote: Check all the wiring that leads from the back of the clocks to the sensor on the front wheel as thare might be a break in one of the 3 wires, this does mean you will have to cut open the "protective tubing" to view clearly all of the wires. Once checked and repair fixed (if there is damage) re cover the wires with at least 3 layers of insolation tape as to be honest that will be more protective than that tubing they use any way.
There were 3 wires, but they did not go into the back of the clocks.
(31-08-16, 08:39 PM)Pike link Wrote: [quote author=Fazer99 link=topic=20477.msg236885#msg236885 date=1468308986]
Where did they lead to then?
They don't go direct to the clocks.  I think they go to the black box of connectors under the tank and from there to the Ignition unit in the tail piece and the speedo gets its signal from there.
(06-09-16, 11:32 AM)Jules-C link Wrote: They don't go direct to the clocks.  I think they go to the black box of connectors under the tank and from there to the Ignition unit in the tail piece and the speedo gets its signal from there.
I will double check when I'm on my lunch but that doesn't sound right to me, as I'm sure mine go direct from the sensor on the front wheel to the back of the clocks.
(06-09-16, 11:46 AM)Fazer99 link Wrote: [quote author=Jules-C link=topic=20477.msg240921#msg240921 date=1473157928]
Just checked and you are correct, I think I must have got the cables mixed up as i was tracking them. I think when I get some free time I might have to see it I can tidy it all up as it's like a bowl of spaghetti under my clocks. I think one of the previous owners must have had loads of gadgets fitted to the bike at some point as I'm sure there are more wires there than are actually needed.
(05-07-16, 10:41 AM)Punkstig link Wrote: What they said
But forget the insulating tape, cut it, solder it and heat shrink it.
I would do that, but the cable is not damaged.
I'm really stuck here, damn I hate electrics.
Have you checked all the wiring and connectors feading from the black Spaghetti box under the tank to the clocks as well as the wires from the front wheel?
If it's messy under the clocks my guess is that's where the problem connection is
I'll have a good look between the spaghetti box and the clocks! Is it easy to get the clocks off?
they are easy to remove once you have removed the front fairing
