01-07-16, 08:50 PM
Evening all. I'm toying with the idea of customising the front end of my fazer. So I'm looking for pics of your custom bikes so I can see what certain things look like
Thanks
Thanks
After some inspiration + pics
01-07-16, 08:50 PM
Thanks
01-07-16, 09:26 PM
Just flapping about on this stagnant little pond on the outer rim of the internet.....yup.... :-))
02-07-16, 03:22 PM
![]() SRAD 750 front end, stem swap very easy, but forks longer than stock, raised the rear 50mm+ to suit
02-07-16, 04:31 PM
don't use the 6 pot nissins if you can help it! see if you can get hold of some 90mm spaced 1200 bandit/triumph 4 pots..................or you could fit some tasty 60mm brembos with adaptor plates and a nice 19mm radial m/c iyswim
02-07-16, 05:51 PM
(02-07-16, 04:31 PM)sadlonelygit link Wrote: don't use the 6 pot nissins if you can help it! see if you can get hold of some 90mm spaced 1200 bandit/triumph 4 pots..................or you could fit some tasty 60mm brembos with adaptor plates and a nice 19mm radial m/c iyswimI've four pots from the 600
« Next Oldest | Next Newest »
