after a new exhaust? have a read here first
so when I bought the fazer last month I knew that I would be replacing the end can, it had been damaged by the previous owner and I originally had planned to stubby it, either that or get another sleeve and replace it. after a bit of research I through out both ideas after I had looked at 51mm slip ons and stumbled across these    http://www.ebay.co.uk/itm/like/38-51mm-M...RTM2108002
I thought for £40 it's got too be worth an investigation and if it's any good I'd tell people about it, if it's shit id stay stum, well i'm telling you about it, so it must have gone ok  :lol
i'll stick up a piccy of the fazer before surgery....
.jpg   20160619_145849 (800x450).jpg (Size: 299.85 KB / Downloads: 368)
my momma always says, stupid is as stupid does.
that's all i gotta say about that
any way, last sunday evening I ordered one of them cans, It was straight forward enough, just paypal'd it and once the order was accepted I was sent a shipping/tracking number (you have to follow the tracking via Hong Kong mail) It was dispatched on tuesday the 22nd and gave a delivery estimation anywhere between July 5th and July 27th......... It came yesterday morning via parcel force  Big Grin
it was well packaged inside a polystyrene and cardboard casing, this contained the can, strap and adaptor. it also contained two springs and two weldable spring clips, I have Delkavic headers and a Micron link pipe, the end can was Delkavic (talk about a friggin cocktail of parts) the end can was held on with a clamp, although the new can has two tags for attaching the springs too.
decisions, decisions,,,, there's a company about a 5 minutes ride away called flowtech that do all things bendy and pipey, they have helped me with bikes exhaust before and made me a beautiful link pipe for a tdm 850. I couldnt be bothered getting the spring clips welded on, so it was out with Mr Grinder  Confusedmash
I removed both tabs from off the can being careful not too damage anything and making sure I left as little weld left as possible so I could finish it off with a file, I also cut 4 small slits to enable the sleeve to close down on the link pipe when it was pushed and clamped onto the link pipe.
a little bit of file work and all was good and fitting snuggly together.
all tightened up and wobbled/shaken to make sure I hadn't forgotten anything and it was time to hear what it sounded like.
with decibel killer in place it gives a pleasant yet still volumous growl, with decibel killer out it gives a rapturous roar (your neighbours will not like you) I don't like him either so the DB killer is sat in my tool box awaiting MOT day.
fitting took about an hour, and most of that was spent filing the thing clean and autosol'ing my link pipe shiny again. you could be quicker if less fussy, or a lot longer if you don't have a grinder and hacksaw the tags off.
I forgot to weight the can, but it weighed naff all, it's alloy sleeve with carbon effect and stainless end caps, I used all original fixings because I trust their strength, I threw all Chinese bolts in the bin as I don't trust their strength.
i'll get a piccy up in a few minutes of the new can.
here you go
.jpg   20160626_173200 (800x450).jpg (Size: 246.27 KB / Downloads: 343)
and another
.jpg   20160626_173210 (800x450).jpg (Size: 233.38 KB / Downloads: 320)
I know we aint always flush and when looking at buying stuff for the bike money always has to be a consideration, my reasoning was why spend between £100/£250 on a labeled exhaust such as Akrapovoc, Leo vinci etc when this could be an option, I bought the renthal copy bars and the Akrapovic can for less than £55. A good result i think.
anybody tempted, or on the lookout for a new exhaust can a  may consider this as an option.?
I like that, looks the business. Keep the ebay link. depends on how it lasts over a year now.
I reckon it will hold up ok. If the carbon effect starts to wear off
I'll  either strip it clean and polish it. Or spray it satin black.
Well done taking the plunge with this one!
Some say...
Hmm, quite tempting that there. My Venom can is looking a spot tatty from previous offs, and £40 is super cheap!
thought silencers have to be tailored made to suit different bikes?
If I wanted to make a life-long career out of
working with the mentally retarded I would
have opened a Harley Davidson Dealership!
In all honesty a straight through pipe is a straight through pipe. Length plays a part in the way exhaust gases leave. But mostly your paying for a name/brand of pipe orc the material it is made of. For £40 these are well put together and without the db killer the exhaust note is infectious
(28-06-16, 06:39 PM)johnakay link Wrote: thought silencers have to be tailored made to suit different bikes?
Lots of silencers (end cans) are interchangeable if you can get the correct size to connect to the link pipe it shouldn't make a difference, (and the hanger should just slide up or down the silencer to fit in with original hanger place)
It's the downpipes and link pipes that you really need to keep to original specs etc although these could be changed too if you wanted to route the exhaust a different way, ie to the other side of the bike but that would involve a lot of measuring and sorting out Sad
Colin
I was wondering how this can has fared in the past 7 months and the winter?
Is that a very small chair or is it a long way away
[img height=450 width=800]http://foc-u.co.uk/index.php?action=dlattach;topic=20415.0;attach=25162;image[/img]
(05-02-17, 01:24 PM)sc0ttie link Wrote: I was wondering how this can has fared in the past 7 months and the winter?
i'm pleased to say that it still looks as if it was only put on yesterday, the finish cleans up really well and the bike is left uncovered outside and ridden daily. the wadding hasn't deteriorated and the exhaust hasn't gotten any louder over time and the rivets are still all secure. to say i'm chuffed with it is an understatement, i'll definitely look at getting another for future bikes. I put an mot on the fazer a couple of months back and inserted the DB killer as i wasn't sure if it was too loud without and it flew through the MOT. best 40 quid spent in my opinion, as long as i can get these i'll keep on using them as if you drop the bike on the right hand side the first thing to hit the floor could be £200 plus of exhaust, if old Betsy hit the floor and the can took the brunt i think i can live with 40 quid rather than my tank or something else take a hammering.  Wink
Seems they are 10 quid cheaper now and in the UK.
http://www.ebay.co.uk/itm/38-51mm-Motorc...3641.l6368
redirected me here.
(06-02-17, 09:31 PM)Skippernick link Wrote: Seems they are 10 quid cheaper now and in the UK.
redirected me here.
thems the ones  Smile  you looking at getting one skippernick ?
For a tad more you can even get "akrapovic" ones  Wink
http://www.ebay.co.uk/itm/Universal-Moto...2264382677
(07-02-17, 11:15 AM)Fazafou link Wrote: For a tad more you can even get "akrapovic" ones  Wink
18 quid more for the Akrapovic ones or £3.25 for the sticker, i love the mark up on some stuff  :rolleyes
To be honest if I didn't already have a genuine akra on mine I would honestly buy one as they look a lot nicer than the one I have on!
And it's only an end can so makes no difference over any other one other than noise.
I know your supposed to get what you pay for but when you think a genuine akra is around £500, are they really 10x better than these?
