Needs a little milling to give it some shape but basically there
What do you think?
![[Image: WP_20160613_009.jpg]](http://s19.postimg.org/5tm0uv643/WP_20160613_009.jpg)
Honest opinion please
Needs a little milling to give it some shape but basically there What do you think? ![]()
13-06-16, 12:34 PM
:thumbup from me if you sink it flush with the tank, not too sure on the raised look.
Colin
---------------------- Ride fast, ride a red bike :-)
13-06-16, 12:40 PM
Cant go completely flush, top of the tank is curved, will worry about the position once I cut out the hole for the steel flange
13-06-16, 01:21 PM
Can not see the point myself but some people will like it.
With the bars in that position, low speed manoeuvrability will be interesting.
13-06-16, 01:28 PM
(13-06-16, 01:21 PM)BBROWN1664 link Wrote: Can not see the point myself but some people will like it. I kind of want it to look a little like a road going endurance/cafe racer, if that makes sense. Just need to try to make it look a little less fake with some paint and brushing of alloy
It doesn't look bad but what's the plan Joe, are you planning to mount clocks on the tank like a Yamaha V star or is it a new filler cap?
13-06-16, 07:04 PM
(13-06-16, 06:30 PM)celticdog link Wrote: It doesn't look bad but what's the plan Joe, are you planning to mount a clocks on the tank like a Yamaha V star or are is it a new filler cap? The tank is now just a cover, with all the underside cut away to allow room for the battery, there just wasn't room for it anywhere else, well not where I could conceal it, so under the tank it goes (tbh there are very small batteries available but at almost £200 I can have an aluminium fuel cell made, still use the stock battery and hide most of the electrics beneath there too) I want to try to make it look similar to the dry break fillers they used in racing, it wont be perfect but then it will be several hundred cheaper. Off to the engineers tomorrow and ask him about machining and pressing a top hat spacer in to give the fillers some height and shape (little to two dimensional atm) Also seen a pair of flange gaskets I may fit. Couple of pic's with cap heads fitted, not sure wjhich type to use yet, like cap heads as they're old school but will have to have a good stare and see if anything else takes my fancy ![]()
13-06-16, 07:29 PM
If I was going to make a fazer 'cafe racer', which I wouldn't, because although I love my incredibly practical fazer, I don't think the main elements are particularly pretty, like the engine, tank, frame or swing arm. I wouldn't say either were show pieces. Although I'm really looking forward to being proven wrong and eating my words.
If it was me, I would cut out the existing filler and weld in a flat plate, and put a nice shiny cap and filler neck on the front right hand side. You can get some really nice filler caps and if you put it on the right you can brim the tank with the bike on the side stand. I'm thinking about making a custom bike, so have looked at my fazer (and google images 'fzs600 cafe racer'), but don't think its the best starting point. I reckon I'll get an xvs and turn it into a lowrider, fat front tyre, stretch out the riding position and fit some bullhorn wide bars. Each to their own huh! ;-)
-suck-squeeze-bang-blow-
13-06-16, 08:32 PM
I would use button heads instead of cap heads, give it a smoother look.
13-06-16, 08:37 PM
I want shopping in the works engineering dept today and wanted buttons but they only had M8 up so just borrowed some of these
Love the look of the probolt flanged, dished, hex heads but not cheap, especially when you need sixteen
13-06-16, 08:39 PM
(This post was last modified: 13-06-16, 08:42 PM by NorthWestern.)
I always liked the fazer 6 as a Base for something like the harris 1200 mcwilliams races.
![]() I have seen a couple of Blandits with similar bodywork looking like the old gs1000 racers and they do look nice.... Intentionally left blank
13-06-16, 08:41 PM
(13-06-16, 08:37 PM)joebloggs link Wrote: I want shopping in the works engineering dept today and wanted buttons but they only had M8 up so just borrowed some of these Must admit the flanged probolts look good, like pukka factory items.
13-06-16, 08:45 PM
![]() ![]() Yes, I think if you get the angle of the seat/sub frame right it'd look puka
13-06-16, 10:38 PM
(13-06-16, 07:29 PM)Bretty link Wrote: I don't think the main elements are particularly pretty, like the engine, tank, frame or swing arm. I wouldn't say either were show pieces.... Although evidently you have polished the swingarm, cut the frame and fitted USD fork. Coming along nicely actually and I like the polished wheels. Nice project.
17-06-16, 03:48 PM
are those fabricated apertures from a low pressure vessel by any chance, they would not make a very good petrol filler because they are made of a dissimilar metal to the petrol tank, and you know what happens with dissimilar metals and liquids--not a good idea.
17-06-16, 08:26 PM
(17-06-16, 03:48 PM)Oldgit link Wrote: are those fabricated apertures from a low pressure vessel by any chance, they would not make a very good petrol filler because they are made of a dissimilar metal to the petrol tank, and you know what happens with dissimilar metals and liquids--not a good idea. The only liquid they will see will be polish and water, its a dummy tank and the fillers are just for show.
02-07-16, 02:56 PM
Need to have the steel flange welded in the tank to mount it but its finished bar choosing the right fasteners
Not perfect but 100 percent better than the 1st picture ![]() ![]() ![]()
02-07-16, 03:25 PM
Nice job Joe but you've got a screw missing in more ways than one :pokefun
Colin
02-07-16, 03:28 PM
(02-07-16, 03:25 PM)sinto link Wrote: Nice job Joe but you've got a screw missing in more ways than one :pokefun Thanks, and I know about both, bike easier to sort lol
03-07-16, 06:04 AM
I like it! Its good to be different :thumbup
« Next Oldest | Next Newest »
