24-05-16, 07:43 PM
Can I use this when doing my shock bearings or should I take it back to Halfrauds for something else..
CV Lith Moly Grease
24-05-16, 07:43 PM
24-05-16, 08:06 PM
(24-05-16, 07:43 PM)Tefer link Wrote: Can I use this when doing my shock bearings or should I take it back to Halfrauds for something else.. Shock bearings?
24-05-16, 08:14 PM
The bearing in the linkage.
24-05-16, 08:47 PM
Then yes, would be suitable, I've a tub of Lith and it gets used for everything bar the brakes.
24-05-16, 10:27 PM
Cheers, thought I'd bought the wrong stuff. I'll get the shock changed and degrease the bearings in linkage.
24-05-16, 10:39 PM
(This post was last modified: 24-05-16, 10:41 PM by fazersharp.)
I have been looking into grease recently and although any will, do they are all mostly based on oil with extra stuff to make it thicker - or stickyer or better for constant turning (CV ) or better crush properties or better for waterproofing, rubber grease based on veg oil and not petroleum oil and so on.
So I would suggest that the very best you can use would be something better suited to the application which is crushing rather than constant velocity (CV). Thats just what I have picked up from (too munch ) reading on the subject. Cause thats what I do ------ I over think things
25-05-16, 05:12 AM
(24-05-16, 10:39 PM)fazersharp link Wrote: I have been looking into grease recently and although any will, do they are all mostly based on oil with extra stuff to make it thicker - or stickyer or better for constant turning (CV ) or better crush properties or better for waterproofing, rubber grease based on veg oil and not petroleum oil and so on. Did you have to put up extra shelving to stock every available grease known to man......just in case :b
25-05-16, 06:28 AM
(24-05-16, 10:39 PM)fazersharp link Wrote: I have been looking into grease recently and although any will, do they are all mostly based on oil with extra stuff to make it thicker - or stickyer or better for constant turning (CV ) or better crush properties or better for waterproofing, rubber grease based on veg oil and not petroleum oil and so on. "...I have been looking into grease recently..." :lol
25-05-16, 07:49 AM
Has anyone got any 'special stuff'?
25-05-16, 08:50 AM
(This post was last modified: 25-05-16, 08:51 AM by fazersharp.)
I dont like CV grease because it looks all grey and dirty, I like white grease and have a tub of Finish line teflon grease for light duty stuff and will be getting some silkoline RG2 grease - that looks like yummy red jam for heaver duty stuff like when I do the swing arm and suspension brackets.
« Next Oldest | Next Newest »
