Hi guys went to use my bike this morning for work and I'm getting a sort of pinking noise from the front wheel? The bike has just passed it's MOT so would have thought it can't be the bearings can it?I've took the break calipers off and the noise sound's like it's coming from the spindle or bearings. Did almost 300 miles Sunday and no problem?I couldn't get the front wheel off to have a look at the wheel because I don't have a big enough hex but it I buy one tomorrow and take the wheel off is it a quick fix in a garage? I need the bike for Mike to do he's magic on Sunday.
Is there a bit of "HEDGE" stuck in the spokes of the wheel :pokefun :lol.....put the bike on full lock and see if theres any sideways play .ive got a hex drive if you want to pop round and borrow it .....
Cheers red. No there's no hedge lol.cant feel any movement but it's definitely a sort of grind like something is catching every other turn. I'll buy a hex tomorrow and see what a garage says.
27-04-16, 08:14 PM
(This post was last modified: 27-04-16, 08:15 PM by Red Ceri.)
Mel, I've got a hex you can borrow and I'm close than Red98, I've also got a spare front wheel if you want to try it to see if the noise goes away, it had new bearings in it beginning of last year. and yes it does have a tyre on it.
I'm in Wickford, Essex SS12 not far off your way to your boat
Appreciate that ceri thanks.not sure I should ride the bike with the noise it's making.but could drive over for the hex?
you can take the wheel to try it out as well if it will help, will get you to Harlow for Mike' s magic touch if yours needs to get new bearings
Cool your a star thanks m8. I'll send you a pm with my number and you can let me know when's best for you :thumbup
I'd expect a bearing or spindle-related noise to be pretty constant. Have you got something caught up under the mudguard?
:rolleyes
No I've checked it's definitely an intermittent noise coming from the centre of the wheel
Might be worth checking the speedo drive on the wheel :rolleyes
Well don't check there then :'( the problem is then you should have bought a proper :faz .lol :rollin
ok all sorted new bearings fitted and all's good.BIG THANK YOU to red ceri for the loan of a front wheel and hex cheers mate :thumbup
Glad I was able to help and its all sorted, was it the bearings?
yes mate that 300 miles we did sunday must have finished them off.
