17-04-16, 09:17 AM
Hi all,
Just had new K-tech springs fitted and my mechanic told me the compression adjuster screws at the bottom of the forks are seized. And he's right! Other than applying Plus Gas daily the only way forward appears to be removing them from the forks. There looks to be a housing which will unscrew from the fork (obviously that might also be seized) , then I can work on them on a bench. Is this a sound plan? Assuming I can do this will all my lovely new fork oil pour out on the garage floor?
To be fair I haven't adjusted the compression in years, so it isn't a major issue if I have to leave them seized but it would be nice to get them working.
Cheers, paul
Cheers, paul
