Carb hoses
Ok, I'll admit my schoolboy error.
I'm swapping my fzs600 2003 foxeye engine and all is going well until I fit the carbs. I have 2 small metal pipes, facing upward, situated on the front of the carbs. 1 between carbs 1&2 the other between 3&4. There is a small pipe outlet on the upper right hand side of the radiator which i am thinking should connect to the 2 on the carbs. I have no recollection  if I took these pipes off or not. Can anyone help as Haynes is as useful as ever on this matter?
Life is never complete. Once you've discovered rock music, beer, bikes & girls, you have the rest of your life to intimately explore each one.. Good luck with finishing that project.
One on the left goes to the thermostat housing under the tank, one on the right goes to the top right side of the rad. :thumbup
So simple when you see it.. Thank you unfazed you're a star..  (Now where does this one go..lol..)... :rolleyes
