Bar end mirrors and blanking plates for Gen 1 1000
Hi
These bar end convex mirrors give a great view of the rear (better than stock to be honest) but as I need to fit an Autocom PTT switch on the left hand bar, it won't fit with these installed, so they are up for grabs. They are in as near "as new" condition as can be after a few hundred miles on the bike (i.e. since I picked it up last month).
Blanking plates for a gen 1 thou (no idea about other models but the bolt gap is 28mm) from Luke / Devilsyam are also included.
£30 delivered, £25 picked up from either Fleet, Hampshire, or Hursley / Bedfont (on work days to be arranged) for the lot.
cheers
Markie
This is what is included:
[Image: IMG_0565_zpsfyl6knqt.jpg]
On the bike front / rear and blanking plate installed:
[Image: IMG_0563_zpssanest3r.jpg]
[Image: IMG_0562_zps0frvdtt6.jpg]
[Image: IMG_0560_zpsvfqax2xm.jpg]
Offers before they get boxed up and stuck on a shelf? Smile
cheers
Markie
Do you know if these will fit on the 600 rather than thou?
I've heard that the bar ends for the FZS are a little odd but not done any research otherwise.
I should think so, the inserts are 12-13mm diameter and go inside Renthals ok. They are approx 32mm long so as long as there is nothing inside your bar close to the end should be good. They could be cut down a bit if needed.
Cheers
Markie
