rear caliper R clips
doing brake pad change today and noticed 3 R clips missingĀ  :eek :eek :eekĀ  luckily the spring plate put enough tension on the retaining pins to keep them in...
Any idea where i can get them from? or the size so i can order some from the bay?
Id like to avoid taking caliper off to measure so if anyone knows itd help.
http://www.ebay.co.uk/itm/Yamaha-FZS-600...SwWKtUyjQI
If it was me mate id be tempted to go for stainless bits..................................
Assuming this is a FZS1000 rear calliper the pin is 6mm dia and the wire size of the R clip is 1.25mm dia.
Clip same as used on the front of the FZS600. Yamaha Pt. No. 3GM25925-00
You could always use some locking wire as a temperery fix.
