Yes I know it's been covered before but bare with me please......
So I've known I need to get a new chain and sprocket set, but in searching on here and fleebay all I can find is open ended chains where I'd need to rivet to get it closed.
So really, I'm looking for a complete ring where I don't need to close it.
Has anyone ever fitted this sort, where did you get it from? How's it been etc etc?
Thanks in advance folks
Colin
as far as I know (that's not very far) theres no such thing? chain is made in a long length and has to be joined together, the reason being that you would have have to at least take the swingarm out to fit a joined up one, if it's that you don't fancy doing it yourself then take it to a workshop or buy one from somewhere that will rivet it for you.
(07-11-15, 09:28 PM)chaz link Wrote: as far as I know (that's not very far) theres no such thing? chain is made in a long length and has to be joined together, the reason being that you would have have to at least take the swingarm out to fit a joined up one, if it's that you don't fancy doing it yourself then take it to a workshop or buy one from somewhere that will rivet it for you.
I meant to actually put that in that I will be taking the swingarm off and doing a wee rear end overhaul on it so I'd rather get a closed chain if I can.
Colin
It's an endless chain you're after then Sinto, The bad news is that they're a bit more pricey.
It might be worth looking into a yamaha OE chain? I think they might be endless
(07-11-15, 09:50 PM)celticdog link Wrote: It's an endless chain you're after then Sinto, The bad news is that they're a bit more pricey.
It might be worth looking into a yamaha OE chain? I think they might be endless  You saying I'm Scottish? :lol
Not bothered about price in relation to cutting off old one, riveting new one etc i think the endless one would be best.
I'll look into Suttons and see what they have.
Cheers celticdog
Colin
OMG
Sutton prices.....
Chain £149.47
Rear sprocket £111.18
Front sprocket. £30.02
Total. £290.67
That might be a bit much
Colin
Really no need for an endless chain.
(07-11-15, 11:20 PM)darrsi link Wrote: Really no need for an endless chain. Can you elaborate on this?
I was thinking along the lines of time to break old one, rivet new one etc as I don't have the riveting tools etc  and the cost to buy them might be as much as getting the endless chain.
Colin
https://www.ajsutton.co.uk/product/YAMAH...GwodwPEPrQ
£144 delivered. The genuine chain is endless but the kit does come with a link if you want to split the chain. The front sprocket in this kit is way ahead of any after market one.
(08-11-15, 08:05 AM)griff86 link Wrote: https://www.ajsutton.co.uk/product/YAMAH...GwodwPEPrQ
£144 delivered. The genuine chain is endless but the kit does come with a link if you want to split the chain. The front sprocket in this kit is way ahead of any after market one. Thanks griff86,
That looks just the job, I was looking at their parts list, never saw the kit
I'll certainly go for that I think :thumbup
Colin
I quite like the Yamaha kit. You get the quieter-running front sprocket and, as you've got to get the swingarm out to fit it, it's a good opportunity to clean and lube the suspension/swingarm bearings at the same time.
When you say the quieter front sprocket do you mean that it comes with the orange plastic thing as factory fitted. And does anyone know how it makes it quieter.
When I come to do mine this is certainly the way I will be doing it so to re lube the swingarm at the same time
(08-11-15, 02:58 PM)Fazerider link Wrote: I quite like the Yamaha kit. You get the quieter-running front sprocket and, as you've got to get the swingarm out to fit it, it's a good opportunity to clean and lube the suspension/swingarm bearings at the same time. That's the reason I'm looking for the endless chain as I'll be taking the swingarm off
You had yours on long fazersharp? Any issues with it?
Colin
Its been there 17 years from the factory -- 15 years with me BUT only done 17k miles (or is it 18k) either way not a lot, so still looking good for now
(08-11-15, 03:10 PM)fazersharp link Wrote: Its been there 17 years from the factory -- 15 years with me BUT only done 17k miles (or is it 18k) either way not a lot, so still looking good for now Ahh right, I was thinking you bought that kit, mines is original I think but it's deffinetly on way out as I'm getting serious tight spots and know I'll need to replace due to previous owners neglect / lack of maintenance. I tried to recover it Ince I got the bike but to no avail
Colin
(08-11-15, 03:03 PM)fazersharp link Wrote: When you say the quieter front sprocket do you mean that it comes with the orange plastic thing as factory fitted. And does anyone know how it makes it quieter.
When I come to do mine this is certainly the way I will be doing it so to re lube the swingarm at the same time I guess it cuts chain rattle as it cushions the link plates, it probably makes the sprocket less 'ringy' too.
Looking back through my records, I see I fitted mine in March 2012 i.e. 38,000 miles ago. So, no issues with longevity.
(08-11-15, 03:33 PM)Fazerider link Wrote: I guess it cuts chain rattle as it cushions the link plates, it probably makes the sprocket less 'ringy' too.
Looking back through my records, I see I fitted mine in March 2012 i.e. 38,000 miles ago. So, no issues with longevity.  3 1/2 yrs and done 38,000 miles? Your keen
Did you fit the above set? Did you come across any issues while fitting it?
Colin
The genuine Fazer600 chain and sprocket kit 5RT-W001A-00 contains a full chain, front silent sprocket and rear sprocket
Compare the prices
http://www.kfm-motorraeder.de/cms/en/gen...TW001A0000
€162,35 including VAT, plus €15 delivery to UK which is about £130
or from AJ Suttoms
https://www.ajsutton.co.uk/spares/partIM...0000&uID=0
£144.8 including vat and UK delivery
Buying these oem items separately cost twice as much
Remember the good old days when the chain had just a removable link with a clip to hold it in place?
(08-11-15, 03:58 PM)unfazed link Wrote: The genuine Fazer600 chain and sprocket kit 5RT-W001A-00 contains a full chain, front silent sprocket and rear sprocket
Compare the prices
or from AJ Suttoms
Buying these oem items separately cost twice as much Yeah that's what I discovered earlier, near on £300 for separate items but I never saw the kit till you and griff pointed it out
Colin
