Engineer wanted to make two foot rest hanger converter brackets
Have a set of hangers I'd like to fit on my FZS, Standard spacing I believe is 75mm and the new hanger is 65mm.
The bottom hole will bolt straight through both hangers into the frame. 65mm center from this to be taped M8 and top hole again to be just drilled to attatch bracket to frame. Top hole to be countersunk Top and bottom to both be radiused
Can anyone help or if you know a man that can
No engineers around this way now unfortunately
I might b able to help and I m not to far away.
(29-09-15, 10:06 PM)chris.biker link Wrote:I might b able to help and I m not to far away.
Thanks.
will pm you later
