24-09-15, 04:12 PM
Anybody fitted this to replace rear brake res
24-09-15, 05:04 PM
(24-09-15, 04:26 PM)BBROWN1664 link Wrote:A tube? I was thinking the same thing. There must be other parts surely ?
24-09-15, 05:25 PM
No, just a clear tube, you can get other colours. Pull the plug from the top to top it up with fluid. Have looked for something similar for decades (no kidding) but there wasn't any tube that could withstand brake fluid and those that used alternative would have to change the tube regularly.
24-09-15, 05:26 PM
a pipe full of fluid will do the same job. Just cant see why anyone would do it apart from to hide the tube away. Would cause problems at MOT time if its not marked for min level.
24-09-15, 08:05 PM
(24-09-15, 05:26 PM)BBROWN1664 link Wrote:a pipe full of fluid will do the same job. Just cant see why anyone would do it apart from to hide the tube away. Would cause problems at MOT time if its not marked for min level.Cant believe I'm being asked Y on a motorcycling forum :wall
24-09-15, 08:10 PM
Do they check brake fluid levels at the mot?
including ones who like chocolate....
24-09-15, 08:21 PM
(24-09-15, 08:10 PM)midden link Wrote:Do they check brake fluid levels at the mot?Not sure but wouldn't take long to refit the stock res/pipe as vertical so shouldn't have to much problem with air getting back into the system I know its creating work but hey
24-09-15, 08:35 PM
seen tube on front brake and clutch on street farters years ago, clutch OK but front brake?
24-09-15, 08:50 PM
(24-09-15, 08:35 PM)chaz link Wrote:seen tube on front brake and clutch on street farters years ago, clutch OK but front brake? Yeah I've seen a similar set up, looked great but also looked like the fluid could surge away from the mastercylinder
24-09-15, 09:05 PM
Why would you bother? :eek When you have a perfectly good secure remote reservoir already fitted :rolleyes
24-09-15, 09:11 PM
(24-09-15, 09:05 PM)unfazed link Wrote:Why would you bother? :eek When you have a perfectly good secure remote reservoir already fitted :rolleyes You have any replacement bolts on your bike? Maybe a hugger etc etc .....Enough said
24-09-15, 09:14 PM
I had a "kit" HRC one in my blade. Looked neat and was no bother at mot time.
Intentionally left blank
24-09-15, 09:17 PM
(24-09-15, 09:11 PM)joebloggs link Wrote:[quote author=unfazed link=topic=18337.msg211178#msg211178 date=1443125133] You have any replacement bolts on your bike? Maybe a hugger etc etc .....Enough said [/quote] Ah!............................No. Hugger does not count as it does something the standard chain guard does not.
24-09-15, 09:24 PM
End of the day I like to personalize my bikes, not going to go as far as something like the Rubyracer project but little details that I feel improves the look of the bike.
Each to their own.............
24-09-15, 09:32 PM
Oh and of course less weight equals faster acceleration. 10lb is the equivalent to about 1bhp so I'm up to about 97 bhp and I've not spent a penny on tuning
Res may not weigh much but every little helps
24-09-15, 09:34 PM
Isnt the reservoir already out of sight
24-09-15, 09:36 PM
(24-09-15, 09:32 PM)joebloggs link Wrote:Oh and of course less weight equals faster acceleration. 10lb is the equivalent to about 1bhp so I'm up to about 97 bhp and I've not spent a penny on tuningSpend less on pies and you get the same result, so in effect you are gaining money as well
24-09-15, 10:03 PM
(24-09-15, 09:34 PM)fazersharp link Wrote:Isnt the reservoir already out of sight Yes but I know its there :eek As for cost, I'm on holiday this week, spent £20 on a new soldering iron, £13 on a Dremel (copy) spent god knows how many hours making a bracket for my clocks out of some spare aluminium, cut down my wiring loom, shaved the ignition switch bracket off the top yoke, made a patern for a one off remote res mount (being made at work) etc etc How much would I have spent on beer etc if I had not spent that time modifying the FZS. Quids in I recon (and I got £25 back selling my surpless to requirement headlights and still waiting for the final price on some other parts I removed) You may see modifying as pointless, but to me its part of motorcycle ownership
24-09-15, 10:16 PM
:thumbup
(24-09-15, 10:03 PM)joebloggs link Wrote:[quote author=fazersharp link=topic=18337.msg211186#msg211186 date=1443126883] Yes but I know its there :eek [/quote] Well that don't make sense -- wont you know that the tube is also there. Im not a modder but I do get that some are, its just that you cant see it and it does ( :thumbup ) not improve performance or looks so that is why I don't get that tone.What about the ugly box that is the front res - now that I would change
« Next Oldest | Next Newest »
