FZS 2003 CARBS
Could anyone advise me if a set of FZS 600 2003 carbs will fit on a FZS 600 2000 model.All looks the same on a photo.CheersĀ
Yep
Not sure mate, a quick look on the A J Sutton site gives different part numbers & prices for carbs.
http://www.fazerspares.com/items/131-1_8...ettors.htm
I still have a set from a fazer 600 1999. That I would put on ebay
If you don't ride in the rain you DON'TĀ  ride
Cheers guys.AJ Suttons do show differing part numbers but the exploded view of them seems to be the same in both 00 and 03
models.Heres hoping anyway.Just bought a set off ebay from a 03 plate with 16000 miles
Later ones have slightly different jets and needles hence the different part numbers but they should be a straight swap
Only time will tell I suppose.Thanks everyone.
im using 1999 carbs on an 03 engine and nothing bad happening
whats the difference with jets and needle?
