Fork oil balls up?
While I had the forks off to remove a snapped exhaust stud I thought it wise to change my fork oil with 15w. Like the numpty I am, I used the boxeye level instead of the foxeye.
It's nice and firm, maybe too firm. Should I remove the excess oil? I'm afraid I might lose the front end cos its not compliant enough.
As in the '98/'99 level?
'00/'01 box eye levels are the same as a fox eye.
The early models don't have the adjusters, so you simply have too much in there!
Apart from being maybe too firm, I'm not quite sure what harm it would do if you left it, but I s'pose the levels have been worked out for a reason!
I wouldnt have thought youd just lose it like that.......id be careful because there has been a change so gradually build up and get used to the new characteristics......do the cable tie thingy to guage how much the forks are moving.
P.s....well done for spelling "lose" correctly......you wont loose by that fact alone Big Grin
Too much oil can shorten the life of seals can it not  Wink
It's a 2003 foxeye Darssi so does anyone know what the air gap is for that?
Good point Midden, might blow a seal.
Noggy, I am pedantic about punctuation and grammar but don't always get it right. No time for the current trend 2 lwaz shrtn my wrds eithr!!!
L8rz
(26-08-15, 08:57 PM)Pickle link Wrote: It's a 2003 foxeye Darssi so does anyone know what the air gap is for that?
L8rz
132mm air gap rings a bell
(27-08-15, 09:53 AM)darrsi link Wrote: [quote author=Pickle link=topic=18051.msg208241#msg208241 date=1440619058]
L8rz
Cheers Darrsi  :thumbup
So by my calculations I need to extract 12.5ml of oil from each leg. Think a syringe will do the job nicely and save me taking the whole lot apart again.
(27-08-15, 03:39 PM)Pickle link Wrote: [quote author=darrsi link=topic=18051.msg208267#msg208267 date=1440665615]
L8rz
In theory yes, although it's more important to make sure the air gap is the same both sides.
I put equal measured amounts in each fork and they didn't level up???
Dunno if there was trapped oil still in there, never did quite figure it out, but I just levelled the oil so the gap was right in each fork and it worked out fine.
(27-08-15, 04:04 PM)darrsi link Wrote: [quote author=Pickle link=topic=18051.msg208292#msg208292 date=1440686383]
L8rz
I did the air gap method as I wasn't doing the bushes and thought there might still be some old oil in there. Both legs were spot on 121mm gap so taking equal amounts out each one should work fine. The old oil was red and crystal clear which is a good sign. The new stuff is blue so it should make the bike that wee bit faster. :Smile
