retrofit labs headlights have arrived...
Hey guys, my xenon retrofitlabs headlight conversion kit has arrived with no instructions (which is a disaster if you're completely crap with that sort of thing like i am) so any help on installation would be a massive welcome, be interested to hear from others who have bought the retrofitlabs kit as well. Cheers, ride safe!
Hi Snakey. I have the the kit mounted.
The best thing i have done on my bike.
What would you like to know?
http://foc-u.co.uk/index.php/topic,15814...#msg181408
Dont try to be the best in town, just be the best, until the best come arround
Just anything you think i may find helpful, little tips or adjustments you made, where did you put the ballasts? cheers fella!
You have to cut the eksisting light connector in 2 pieces. ( Photo) Then it fits the new connector form Retrofit lab. (the H4 bulb connektor)
I put the ballast under the speedo and rpm.  When i put them there, the wire to the bulb fits.
I had problems with the position light bulb. I found at shorter connektor.
I have removed the [color=rgb(102, 102, 102)]The Mini Gatling Guns. the glue dident hold.[/color]
[size=78%] [/size]
.jpg   Retrofit stik.jpg (Size: 30.43 KB / Downloads: 49)
