Wanted Fazer 600 Foxeye TPS
My TPS is starting to play up. I have checked it iaw the Manual and the overall resistance is out of limits at 7.5K Ohms and when I set it up to 5000 on the Rev Counter (Diagnostic Test) then put a meter between the centre (Yellow) and upper (Blue and Black) and turn the throttle the readings jump all over the place (Manual says should go from 0 to 5000 ohms)
Even if I just have the leads fitted and don't touch the throttle and tap the side of the TPS the reading jumps about.
I've seen one in a Breakers for £38. But hoping somebody might have a spare lying around.
Cheers
John S
For anybody that might need one in the future this will give you another option to add to the list.
As well as lots of Suzuki's and other Yamaha's that have the same TPS. I found that the TPS of a XT660X 2004 also fits. Just remember to take the little rubber seal off the shaft on the sensor.
New one reads as per the manual.
