I've finally got around to replacing the chain and sprockets on my FZ6, but I've hit a little snag...
The Haynes manual says the bolts on the rear sprocket should be tightened to 100nm, but my torque wrench only goes up to 50nm...
So how do I get to 100nm?
Do it twice
100 nm - is that two or three white knuckles? :lol
(Buy a bigger torque wrench!)
1m long spanner with you stood on the end assuming you weigh 100kg will work.
29-07-15, 09:26 PM
(This post was last modified: 29-07-15, 09:28 PM by pilninggas.)
(29-07-15, 09:19 PM)BBROWN1664 link Wrote: 1m long spanner with you stood on the end assuming you weigh 100kg will work.
that would be way too much torque; 100kgf = 980Newtons (x1metre) = 980Nm of torque
I have an 18" norbar torque wrench and it's pretty much that with my full applied arm effort (weedy southern nancy)
seriously now, they're 8 or 10mm thread, just lean on them. common sense will tell you if they're tight.
Wrench it until you fart.
If you shit yourself it's too tight. :lol
(29-07-15, 09:26 PM)pilninggas link Wrote: that would be way too much torque; 100kgf = 980Newtons (x1metre) = 980Nm of torque
Ah, now *that's* a useful reply :thumbup
It's been a very long since I did physics, but you've reminded me how to figure it out.
I've got a socket wrench which is about 20cm long, so if I needed to apply 10kg on a 1m wrench then that would be 50kg on a 20cm wrench, ie pushing down with most of my weight would do it.
Thanks!
(29-07-15, 09:56 PM)Grahamm link Wrote: [quote author=pilninggas link=topic=17798.msg205457#msg205457 date=1438201596]
Thanks!
Cheers,
That suits me; I'm a Design&Tech teacher and in september i'm also teaching science, so at least i'm explaining things correctly.....
Good rule of thumb finger tight then one flat on the nut and for extra security apply a touch of Loctite Blue before assembly.
(29-07-15, 10:48 PM)lew600fazer link Wrote: Good rule of thumb finger tight then one flat on the nut and for extra security apply a touch of Loctite Blue before assembly.
You are obviously joking for 100Nm?
Unless you have fingers like "The Thing" from The Fantastic Four?
(29-07-15, 11:12 PM)darrsi link Wrote: [quote author=lew600fazer link=topic=17798.msg205472#msg205472 date=1438206516]
seriously now, they're 8 or 10mm thread, just lean on them. common sense will tell you if they're tight. (from someone else on here)
The rear axle nut is 150nm , I don't have a torque wrench that goes to 150nm so all I have done with that is mark the flat of the nut and the area next to the nut, Back it off do what I need to do and tighten it back to were it was. All I am using is a split ring spanner no bars or anything else and I am not popping a vein to slacken/tighten the nut. Now perhaps it has not been torqued up to the correct torque in the first place , but guess what the wheel has never come off or come lose on me yet. All I am doing from finger tight is turning the nut through 1.5 flats
After spending my working life as an engineer I reckon I would have a pretty good idea when a nut is tight.
So how many flats do you reckon from finger tight on a 8-10mm bolt/nut do you reckon you would need to turn it to achieve 100 nm?
(29-07-15, 11:57 PM)lew600fazer link Wrote: [quote author=darrsi link=topic=17798.msg205475#msg205475 date=1438207940]
If i get a sporting chance i'll give it a try at work and let you know.
Common sense always prevails, but it's probably the lower settings where people really get it wrong, like exhaust header nuts(12Nm), caliper pad pins(10Nm), etc.
Even worse if using copper grease, where even i have become a victim of foccing up my own rear caliper, using a torque wrench.
(30-07-15, 07:35 AM)darrsi link Wrote: [quote author=lew600fazer link=topic=17798.msg205478#msg205478 date=1438210627]
Cheers Darrsi, maybe my old grey cells are not what they used to be , my son told me last night that he thinks I am starting with Alzimers as I keep asking him stupid questions.
I spent my time a s a marine engineer on a lot of nuts, studs bolts etc! we would use hydraulic stretching gear on the stud and then just follow the nut up by hand and release the hydraulic pressure , pretty sure this is not just the domain of the marine industry. Other methods was a hot poker down the centre of a stud heat it up fit the nut and tap round with a skeleton spanner one flat and remove the hot poker as the stud cooled you got the correct torque setting.
The thing is just a small movement of a flat can be a huge difference in torque, especially with the higher numbers, so it is still quite random doing it that way.
Are you sure it's 100 nms seems a lot, you do mean the bolts that hold the sprocket to the hub?
A 100nms coverts to 73.76 foot pounds, using a 1/2 drive standard ratchet wrench the most you can get without swinging on it is around 75 foot pounds, ok some will get more but the fitter who told me set up a bolt in a vice and I was within a couple of pounds of it, so it's ok as a guide.
I took my rear sprocket off to paint a few months ago and didn't tighten them up that tight but I did use thread lock.
and shouldn't sprocket nuts be nylocs anyhoo?
(30-07-15, 10:50 AM)chaz link Wrote: Are you sure it's 100 nms seems a lot, you do mean the bolts that hold the sprocket to the hub?
I took my rear sprocket off to paint a few months ago and didn't tighten them up that tight but I did use thread lock. +1!
Are you SURE that the sprocket retaining bolts should be tightened that amount. Dont have my Fazer workshop manual any more since I sold bike but what are they 6mm or 8mm diameter?
Certainly the rear axle needs a high torque setting something over 100NM from memory but surely not the sprocket bolts? Just recheck book to be on safe side & as already suggested use a dab of blue loctite on the threads.
That's exactly what it says in the Haynes Manual:
Rear sprocket nuts: 100 Nm
Rear wheel axle nut: 120 Nm
I'm going to use Threadlock as well anyway.
100 Nm is correct, (boxeye is 60Nm) for the sprocket. Buy a torque wrench you need one to tighten the spindle too!
