26-07-15, 06:11 PM
A couple of months ago, I changed the antifreeze of my fzs. As it was very brown and with a lot of mud, I cleaned the circuit with a lot of water until the water was transparent, and finally put 20% antifreeze...
Now, the green antifreeze is brown again, not so muddy as before, but the problem is there again. After disassembling all the hoses, there are two metallic pipes that looks like are rusting inside (the two next to the cylinder number 1).
So... If I clean the pipes again (pipe by pipe) and fill the circuit with antifreeze, will it rust again? Should I pay about 180 euros :eek for a pair of new pipes?
