13-07-15, 08:29 AM
Anyone had a problem where the internal screws come loose? I had a problem recently where my indicators stopped working, but if I moved the key they would work, but a short time later they stopped again, eventually I noticed the barrel housing was moving, I took the barrel off the bike used a dremel so I could remove the 2 shear screws and tightened up both screws, the barrel I have is a replacement but there was no signs it had been taken apart, apart from the covering blanks being missing.
