Spot light on indicator?
Hi,
I may have dreamt this, or it may have been in another forum... but I saw relatively recently someone who had fitted a spot light to their indicator for when on full beam. I was trying to find the post and can't so I thought maybe one of you eagle eye foccers could help me?
If it was on another forum I apologise, I promise I don't cheat on you lot usually, it was a one time thing, honest  Wink
HJF
This might be what your after...
http://www.bikevis.com/motorcycle-led-ru...ights.html
There is the mod to use the dip filament of the right hand headlight and have both sides lit on dip.
But I think the threads you refer too were by Paulfzs, he has done three threads I think about lights, I think these are the main two,
http://foc-u.co.uk/index.php/topic,15368...#msg175026
http://foc-u.co.uk/index.php/topic,15666...#msg179206
The bikeviz bullets don't give any light just make the bike more visable. Ebay is full of equivalents now - I have a couple fitted and were £4 fitted and look just like the bikeviz ones.
If you want extra light then there are lots of ways
- as above run two lights,
or run HIDs (and both lights),
HIDs with reflectors (big job involving splitting the lights with heat and resealing,
Run LED headlights - they are dearer but have a neater pattern and Mr MOT likes then ( I have one on Dip)
- or fit spot lights - lots of versions on fleabay and you could use a use HID or LED versions. Easy enough to wire in
Cheers Guys, it was the PaulFZS thread I was looking for, thanks!  Smile
