looking to change sprockets, they dont "need" doing but i want to bring revs down for motorway trips, would +1 on the front only be fine or do i have to do rear aswell?
will it make it accelerate too slowly if i just do the front
ive read about loads putting -1 for better acceleration to better utilise 6th gear but standard sprockets feel god aweful on the motorway
You can have a play around with yours ratios here fella
http://www.gearingcommander.com/
going up 1 on front will cause you to work harder in lower gears and when you get in top (if you do) you`ll end up dropping down to 5th or even 4th to overtake etc
standard is pretty good all round
but dropping -1 will give better results and ride better in traffic and TBH unless your doing 100+plenty your not gonig to benefit by going +1
waters wet, shit stinks !
im often sat at 70-80 and it feels too revvy for my liking, i dont mind dropping gears to overtake its worth it for the fuel saving.
up to you mate your ride not mine
just trying give you good advice
what RPM does the stock ratio sit at doing 70-80, i have never really looked as i only really hit country roads, and never really am looking at the speedo etc...
Sooo, a while ago I swapped the rear wheel from the written off thundercat to the fazer as the tyre had more life in it.
Didn't bother swapping sprockets as I thought they were the same, they're not, the Thundercat has 47 teeth.
Now I realise -1 on the rear is little difference compared to changing the front sprocket, but in relation to your queery- it's had little effect on acceleration (if, if I wanted to it'll still wheelie happily enough) and to me it feels comfortable on the motorway at 80ish!
For the power of the bike I think you'll have little problems with acceleration changing the front sprocket by one!
Some say...
i dont mind loosing some acceleration as itll pop up in 2nd with the clutch and 1st under power which id like to get rid of really as spritely acceleration off lights often ends in the front wheel off the floor.
ill go +1 on the front and see how it copes if i need a little more acceleration ill go -2 on rear.
its all personal choice and what you feel happy with as we all ride differently and want different things from our ride
personally i find it very rare that i`m doing 162mph and rarely ride on motorways (kin boring)
most of my riding is on lovely country back roads
scrathing etc 40mph -120mph
or with the mrs on back
either way i find that 14-48 is great pulls strong and labours well in traffic
and returns 150 to a tank
even on an all day blast still get 120 to a tank
great cheers all taken on board will see how i get on.
