23-05-15, 02:54 PM
Hi All,
I've just bought an X plate 2000 FZS 600 as a second bike / something for Mrs P to ride after she does her test and it won't start with the side stand down.
Its fine on the centre stand or if you just hold it up and start it. If its running whilst on the centre stand or you are holding it and you put the side stand down it instantly cuts out (all of this is while it is in neutral of course).
Because it starts on the centre stand I assumed that the clutch microswitch is ok and also the starter and relay etc so decided the sidestand switch must be shot as the plunger was a bit sticky and WD40 seemed to make no difference - so off to fleabay for a replacement (2nd hand)switch - just fitted it and absolutely no different.
I'm assuming that there is some sort of interlock or something somewhere - the net seems to have loads of people with the same problem but no real answer (that I can find).
The bike looks like it had an alarm fitted at some stage but its been removed, but some of the loom is still left in place.
It isn't a huge problem at the moment, just annoying, but would like to sort it before Mrs P uses it as she is a bit short in the leg and the side stand will be easier for her to use.
Any help or suggestions greatly received....
