Phew!
Had to do an emergency stop on dual carriageway on commute home tonight :eek
Probably doin 65 when I have to slam on the anchors . . . only to have the back end slide out to the right on me!
I'm going to hit the rear end of white van man side on, the rear wheel's locked and I'm panicking- came off the rear
brake, I think I did?!? Bike starts to fishtail, back on the brakes and I managed to stop about 2ft and at an angle of
45 degrees from the back of this transit. Limped home and changed underpants. :rollin
Thank god it was dry, anyway :o it's made me realise I don't know how to handle the bike in such situations, normally
I'm a 75 front 25 rear breaker, what should you do? Also, what would be the best reaction if it was wet conditions?
I used to do the same with braking , until i did the Ron Haslem track day where they tell you not to use the back brake unless for low speed manoevres control . I would recommend the Ron Haslem race school to anyone .
Cheers Esetest, was it easy to stop using the back brake?
I'm definitely 'hard wired' to using the rear, but I'm willing to give it a try.
Will defo look into the Ron Haslam race school, it can't hurt to develop better technique.
Would this change in wet conditions? I seem to remember 50/50 braking being recommended . . .
Celticdog...dont be too hard on yourself....you didnt crash.
Are you an old school biker out of interest???...just ref the use of back brake im curious.
Under heavy braking weight transfer puts a lot more weight on the front and less on the back. Hence easier to lock the back. In the wet you can't brake as hard without locking the front so less transfer and the rear can contribute a bit more in proportion to slowing down. But even in the wet the front is still doing most of the work. Anticipation and smoothness is the most important thing.
Well done for a good save though
As said, you didn't lose the front end or bin it so pat on the back fella.
Me - same as you 75-80% front 2 stage braking to compress front tyre first + a dab of rear. Much the same in the wet - although I can cadence brake the front up to about 20-25mph ish.
Was it a brake only option or did you pick out an escape route.
Hey when I passed my test I was taught it's all about the front. The rear brake is only for slow maneuvering. .
When you have to do an emergency stop the fronts got all the stopping power and as soon as you stick it on all the weights shifted to the front, so the rear brakes not really doing much.
I was taught the same for wet too .. Although i had to do an emergency brake at 60 odd mph myself the other day iv never had to do it in the wet over 40mph but id say the same applies ... just remain extra vigilant .. it's all you can do really.
Being an older rider i was taught to use both the front and brake combined , at the race school they tell you front only . they even get you doing stoppies , which is great fun , they provide bike , leathers, helmet , boots ,gloves , you don't even need a license .
TBH I'm the same, always end up locking the back up when doing an emergency stop. Though not had it swing round yet. Either way, it's not good and something I do need to work on. I think a lot stems from always covering both brakes due as for 80% of my commute I'm filtering between gridlock traffic...
I've been doing an IAM course this year, first thing they did with us was a machine control day on an airfield, covering lots of reasonably basic stuff: emergency stop in short distance, slalom at speed (counter steer practice) and full lock to lock circle-figure 8's at 1-3 mph. Really highlighted bad habits and stuff I need to improve on - all in all really useful. Their guidance was back brake only for low speed stuff (and then control speed just with back brake, keep throttle/clutch constant).
Won't be as exciting as a Ron Haslem track day, but I've certainly found IAM useful to tidy up my riding a bit.
When I upgraded to HEL brake lines I did no do the rear so it was not TOO good
(20-05-15, 09:31 PM)Arfa link Wrote: TBH I'm the same, always end up locking the back up when doing an emergency stop. Though not had it swing round yet. Either way, it's not good and something I do need to work on. I think a lot stems from always covering both brakes due as for 80% of my commute I'm filtering between gridlock traffic...
Won't be as exciting as a Ron Haslem track day, but I've certainly found IAM useful to tidy up my riding a bit. I did a level 1 california superbike school day which was a bit tame on track but they had some low speed stuff which turned out to be good practice. I never really used the back brake for years and anyway a lot of them didn't do much, probably for good reason. Have been coming round to using the back more and the 1000 rear is to me a powerful rear brake, mind you i did have some H****s that had the linked brakes so didn't have a lot of choice.
Thankfully you and your bike are ok celticdog, maybe not your underwear :eek
Did you cadence brake at all? From your description it sounds that you grabbed a fistful of brake and pressed the rear down?
I ask, as I've had abs braked bikes for years then I got this after being of bikes for about three years, and first time I went to press the brakes in earnest (albeit I was on a clear road and wanted to check how the brakes were) it nearly locked up then I thought this doesn't have abs :eek so practiced my cadence braking to get in my head what I was doing.
I'm guessing many a rider forgets its not grab brakes and it'll do the work for you.
Colin
I quite often like to have a practice hard braking SO LONG AS there are no other cars around on the approach to a red light to leave it as late a possible to brake and stop from 40, practicing keeping off the back until slowed right down. Also when you are braking on the front you are transferring all that weight to the front tyre which will make it compress and grip even more
Cheers Guys,
some good information here. Tbh I think it was just instinct for my right side hand and foot to tighten up and hit both brakes simultaneously, I'm happy to have had a near miss with this one to be honest.  thankfully things have changed a bit from the
air cooled kawazaki I started out on, the fear was that you'd pop the fork oil seals hitting the front brake too hard . . .
I'm going to have to read up on cadence braking and give it a try.
(20-05-15, 10:41 PM)celticdog link Wrote: I'm going to have to read up on cadence braking and give it a try.
Everyday is a learning day
It's a lot easier to read up on it, practice is another thing, try doing it as suggested above by fazersharp, as your going to have to stop anyway, press on, release, press on, release, press on. Start with lower speeds and work your way up to higher speeds, but always remember and check behind you before you start to try it.
As I said earlier, we all just grab the brake hard when we are in a situation, but our poor bikes don't have abs and this is the way abs actually works but needs human input.
Colin
I see nobodies mentioned road craft, don't get into that situation in the first place,
Front end slides tend not to be controllable, you stand a small chance with a back end slide.
I recommend some off road riding get used to feeling the bike sliding around.
learn how to use quick shift downs, engine braking.
The road isn't the track,
Candice braking is key!!! In an emergency stop, never grab a fist full and yes rear is next to useless!!! True to say with defensive riding you should be doing everything to avoid such a situation....... But it happens..... You can't control or predict everything (else accidents would never happen!) sounds like scary as it was you maintained control....... Well done
As has been said before, I was taught front brake all the way. Gradually on at first to transfer the weight to the front tyre, then as it grips brake more. Forget the rear brake.
I can recommend the advanced cornering course at Mallory Park:
http://www.circuitbasedtraining.co.uk/co...allory-325
I did it two years ago and it covered emergency stops round corners at high speeds, plotting escape routes etc, but also braking in a straight line to the limit of what the bike's capable of. They let you practice until you get the technique right, then do it at higher and higher speeds. At my fastest I felt like the back end was fishtailing out on me like fuck, but it was still safe (the bike doesn't move half as much as it feels like it does!).
I actually gained more confidence and skill in stopping than I did in cornering on the course.
(20-05-15, 07:24 PM)celticdog link Wrote: I'm a 75 front 25 rear breaker, what should you do?
In an emergency stop situation, your front brake is going to be doing virtually all the work, the rear may actually be barely in contact with the ground, so any more than a small amount of pressure on it will cause it to lock.
It's a good idea to find somewhere out of the way to practice three stage braking:
1) Take up the pressure on the lever to light the brake light and begin to engage the front brake to feel how the bike responds.
2) Smoothly and progressively increase the pressure on the brake, continuing to feel the reaction. If it feels like the rear is starting to lift or the front may slide, release the pressure slightly, then reapply.
3) As you get to the speed you want (which may be zero), reduce the pressure, ideally releasing it completely as you reach the target speed.
The aim is to get a smooth progression in pressure giving controlled braking, rather than just grabbing a fistful and hoping, but ideally, of course, don't get into the situation in the first place. If you can't see what's ahead of the van or other vehicle in front, drop back to give yourself more space and time to react.
Quote:Also, what would be the best reaction if it was wet conditions?
Braking distances on wet surfaces are going to be longer and with a greater risk of skidding, so reduce your speed and increase the separation between yourself and the vehicle in front to get more time to react and stop.
Not one of you has mentioned DON'T TOUCH THE CLUTCH???
That's what causes the rear to want to overtake you, or fishtail, because you've released the engine braking!
Makes a world of difference!
