cooling fan
how often do you guys hear your cooling fan kick in?
I had a bit of a enthusiastic ride the other day and when I pulled up at home and left the bike running while fluffing moving cars and opening the garage I never heard the fan kick in, infact ive never heard it. the red OMG light had never flashed either.
never....wandering if mine needs checking actually...
Only only very hot days in traffic, these bikes handle heat quite well. If your cooling system is operating correctly, and not clogged up, it seems to be enough in normal circumstances.
My previous bike's fan used to kick in all the time at the slightest hint of heat.
Saying that, it's not a bad thing, that's what they're there for.
I did a cooling system flush etc over the winter , so I know that its clean and coolant mix is correct... I had a zzr that lived on the fan and my gsx1400 was oil cooled with a HEL oil cooler and other upgrades and the fan for the oil cooler would kick in on hot days.
just didn't want the fazer boiling up as I had not heard it.
cheers for putting my mind at ease.. no doubt somebody will pop along all doom and gloom.. :rollin :rolleyes
(09-05-15, 02:25 PM)stevie-g1968 link Wrote: I did a cooling system flush etc over the winter , so I know that its clean and coolant mix is correct... I had a zzr that lived on the fan and my gsx1400 was oil cooled with a HEL oil cooler and other upgrades and the fan for the oil cooler would kick in on hot days.
No, some people have never heard their fan since they've had their bike, they really do cope quite well without it kicking in.
Even on hot days at a standstill in London it doesn't come on, the fzs600 is renowned for having one of the best cooling systems ever!
Some say...
(09-05-15, 07:37 PM)Punkstig link Wrote: Even on hot days at a standstill in London it doesn't come on, the fzs600 is renowned for having one of the best cooling systems ever!
Along with some of the coolest riders Smile
Colin
Never heard mine in 14 years, changed the cooent last year and let is sit running with some flush in and got bored waiting for the fan to come on -- it never did, everything was getting hot making ticking noises as parts started to expand- smelt hot too, I wonder if it even works
(09-05-15, 10:57 PM)fazersharp link Wrote: Never heard mine in 14 years, changed the cooent last year and let is sit running with some flush in and got bored waiting for the fan to come on -- it never did, everything was getting hot making ticking noises as parts started to expand- smelt hot too, I wonder if it even works
:lol
.png   Capture.PNG (Size: 589.29 KB / Downloads: 57)
Mine started once when I did the carbs sync. It was an hour running at idle and low rpms.
(10-05-15, 10:34 AM)rhinoeli link Wrote: Mine started once when I did the carbs sync. It was an hour running at idle and low rpms.
As i said before there's no harm in that, it's a good thing, that's what it's there for, plus it's good to know it's working if needed.  Smile
Ah I see I only waited 20 mins
Manual section 8-53, shows connecting the 12V direct to see if it turns......i.e. if it even works - shall see what mine does....
8-54 also shows them testing the thermo switch by heating it in a bath of coolant....not sure i want to try that!
(10-05-15, 11:27 AM)anutz link Wrote: Manual section 8-53, shows connecting the 12V direct to see if it turns......i.e. if it even works - shall see what mine does....
It will work, i wouldn't worry about it.
i can't stop thinking about it now!  :'(
(10-05-15, 11:37 AM)anutz link Wrote: i can't stop thinking about it now!  :'(
If that's bothering you, wait 'til you get the cam chain rattle.  :lol
If you short the connector going to the back of the fan with a bit of wire it'll come on.
wired mine into a switch so i hear mine quite a lot Big Grin
i will put mine on if im on the track or hooning around in low gears....
rather be safe than sorry.
I see ive opened that can now :rollin :rollin... I know the fan works as I shorted it to bring it on, im not fannying about sitting in a bath of coolant to see if the switch works.. il just wait for the red light to flash :lol :lol :lol
I did a 140mile thrash around bucks and oxon today and left it idleing again... nope didn't come on so I will go with the" It will be fine " way of thinking. :rolleyes
Read this the other day thinking I hadn't heard the fans on my bike yet and then rode 200 miles yesterday and when I stopped the fans were really going. I did ride her pretty hard and did a solid 40 miles on the motorway too.
