starting problem
Hi all ive got a slight problem, whilst coming home from work today I stopped at a shop when I came back to the bike it wouldn't start just buzzing noise under the fuse box I managed to bump it off and it started off the start button after that, it done it once before a couple of months ago but has been fine until today, any ideas please
Sounds like your battery is goosed Jimbo
I was thinking that mate but it starts on the button every time apart from today and a couple of months ago even if I haven't used it for a couple of weeks it starts first time. I thought iffy starter/selanoid  maybe
A multimeter is a useful bit of kit to help pinpoint these sorts of problems.
Clean and tighten all the electrical connections and squirt a bit of contact cleaner at all the switches before assuming the battery is knackered.
Hi, you are right the buzzing noise is the solenoid but before you change check battery connections & all others leading to the solenoid & starter motor are all clean/tight. If it fails to start on the button again put bike in first gear ignition off & move bike forward & back put back into neutral switch ignition on, if it starts on button suspect faulty starter motor.
thanks for all the tips thats my job for the weekend then, again thanks for the help
Hi all, changed the solenoid and made no difference, got the battery checked and found it is dead so new battery required
(01-05-15, 09:31 PM)jimbojim link Wrote: Hi all, changed the solenoid and made no difference, got the battery checked and found it is dead so new battery required
Are you sure it's dead?
I remember an old bike I had, the battery showed dead but I stuck it on an optimizer for a few days and lo and behold, brought it back to life and continued to use it, all I done afterwards was kept it on a trickle charge and never had to buy a battery so maybe worth a try?
Colin
Batteries only realistically have a few years of optimum performance, if that.
Remember they are charged EVERY time the bike is used, that's a lot of charging and discharging.
A phone's battery has a fair life expectancy of TWO years so once you consider the shite a bikes battery gets put through, especially with hot/cold temperatures, then it only makes sense to change it when you get a hint of problems.
And for the amount of years you'll get out of a decent brand, it makes no sense to cut corners and save £10 or £20 on an inferior battery.
The chances are you'll only ever buy one (perhaps two at a stretch) battery for the whole time you own the bike.
changed the battery it fired up first push of the starter button Smile, no point fookin about at least I don't have to worry about the battery for a long while
(02-05-15, 07:11 PM)jimbojim link Wrote: changed the battery it fired up first push of the starter button Smile, no point fookin about at least I don't have to worry about the battery for a long while
Glad you got it sorted now :-)
Colin
