Front Wheel fitting...
So I am slowly getting bits back on my bike whilst I await some parts I need to finish putting the cylinder head back on!
I put the front wheel back on today and the callipers etc...
It rotates but not as freely as I would have thought....I made sure that the speed sensor unit was lined up as it should be and its all torqued as needed...
Both sets of disc brakes are rubbing - not sure I would call it binding but when I spin It with a free hand, it does not rotate much due to the friction..
Would this be explained as "normal" given the pads might be in a little different position now?
Or is this something to look into and re-assemble/clean resolve?
Anutz!
Normal reason is putting pads back in different positions, or sides.
If this is the case then they'll take a few days to bed in again, but it's not a problem.
