08-04-15, 10:13 PM
Ok so I started my bike up this afternoon everything working ok, then it was just as if I'd turned it off, the engine stopped and the lights went out. The only thing that worked was the hazard lights with ignition on or in park position , the indicators in the on position and the parking lights in the parking ignition switch position. After twiddling everything worked again for about two minutes and then the fault returned as before.
Currently I have a supply to the fuses under the seat that goes on and off with the ignition switch, all lights ,horn, starter etc don't work except the indicators/ hazards work as they should. I had to call it a day earlier and I'm going to resume tomorrow. So has anyone had this before and if so what was it?
Cheers
Andy
Cheers
Andy
