rebuild/Referb front forks.
Has anyone had this done i think mine may need doing as not sure if dekF ever did it. Tried contacting him hopefully he will let me know, Has anyone had there's done costs ? companies who did it if possible.
Hello mate
Just had my gen 1 forks serviced. Give my friend Stef Winman a call from tyres4bikes ltd and tell him I sent you and he'll run through different options with you. Number is 01775 840254
Cheers
Lewis
Smile will do.
You are looking at a little over 100 quid if you do it yourself,  for new springs, oil and seals. The same plus 40-50 quid for a local independant type mechanic if you are a bit of a spanner numpty Or about 300 quid if you send them to one of the big name suspension fettlers, KAIS, K Tech, Maxton, MC Technics, HM Racing etc
Are they standard forks?
If so then easy, are you just changing oil or need to change springs?
Just need a spring compression tool,easily made
