Sorry - another gearing question
hi all, gen 1 1000
I understand the std gearing to be 16/44
I've been doing some cleaning etc and found that the previous owner had fitted a 17/45 combination.
Sorry, I still to this day can't get my head around gearing so please could someone tell me in simple terms what effects this gearing has?
Also I noticed that the chain has made marks on the rubber on the sides of the front sprocket where the rounds of the side plates seem to be touching it.
I like things standard too so probably swap back to standard but would like to gain an understanding.
Cheers
Lewis
I'll try to keep this simple.  Like me.
Reducing the size (number of teeth) on the front sprocket lowers the gearing, which means higher engine revs for a given road speed but quicker acceleration.  Also, it will increase fuel consumption at cruise speeds.
You have a larger front sprocket, though, which on its own would raise the gearing and give the opposite effects to the above.
However, you also have a larger rear sprocket than standard which changes things again.  Stay with me. Smile
Fitting a larger rear sprocket (more teeth) lowers the gearing, the same as fitting a smaller front sprocket.  In your case, the PO has done a bit of each.
The extra tooth on the front sprocket has a greater overall effect than the single extra tooth on the rear, meaning you bike is higher geared than stock.
In theory, you have a little less acceleration on tap but cruise rpm for a given speed will be lower, hence marginally better fuel economy.
Usually if owners change the gearing on a Gen 1, then drop a tooth at the front - and possibly go up one or two in the rear - to make bike more responsive.
I've never tried lowered gearing on mine as I'm perfectly content with how it performs on stock cogs. Smile
Mike,  can you repeat that again for me please, was with you up until you said "simple"  :lol
Thanks Mike, I think I get it now.
Back to standard cogs for me I think.  Big Grin
(20-03-15, 03:39 PM)dazza link Wrote: Mike,  can you repeat that again for me please, was with you up until you said "simple"  :lol
Well done ... I lost meself just before the full stop after simple :lol
surprised noones added:
www.gearingcommander.com - excellent way to model different gearing configurations.
