14-03-15, 12:44 PM
OK, starting my "second life" on FOC-U with a cry for help!
Bike is a 2003 FZS1000
I recently put new clutch plates in and also a new clutch cable (also did an oil change at the same time). When the bike is warmed-up, the clutch is fine, but when its cold, the cable has tightened-up taking the play out of the run and the clutch draggs really badly and won't fully disengage. Once it warms up after a couple of miles, the cable slackens-off to give the correct play and the clutch works fine again
Any suggestions or assistance will be much appreciated.
Cheers,
Jon
Cheers,
Jon
