Ok, so I am now the owner of 3 TPS's.
All of them are reading 10,000 regardless of how much I adjust them.
I did exactly what the manual says. Warm the bike up, set the idle to between 1150 and 1250.
It wont budge from that 10,000 mark.
I've even tried turning the idle right down (3 - 4 turns more) just incase where the idle is is whats causing the 10000 reading.
I just dont get it.
Is there anything else I can change / adjust to see if I can get it to lower from the 10,000 mark?
Thanks
I assume your rev counter works properly when it is connected normaly, and gives sensible indication of engine speed, if so check the condition of the conections on the Ignitor module and check the continuity of the three wires, think they are Blue, Yellow & Black with Blue stripe
(03-03-15, 06:52 PM)Ebme Geek link Wrote: I assume your rev counter works properly when it is connected normaly, and gives sensible indication of engine speed, if so check the condition of the conections on the Ignitor module and check the continuity of the three wires, think they are Blue, Yellow & Black with Blue stripe Hiya, yep, tacho works fine normally. The ignitor module, is that the CDI unit?
unplug tps, switch ignition on, plug in tps
then undo the 2 screws and very very slowly move it... like just under a mm very slowly and watch the tacho to see if it moves at all.
if you go too fast and skip past it then the tacho wont move.
it really does have to be minute adjustments.
(03-03-15, 07:09 PM)Paulfzs link Wrote: unplug tps, switch ignition on, plug in tps
I thought that if they are at 10, 000 and I moved it passed the "sweet spot" then it would jump to 0.
I have tried moving them really slow,( I've even put them on backwards and then turning them) but it just sit's at 10,000
It's what you are thinking of but, the FZS has transistor ignition as opposed to Capacitor Discharge Ignition.
As your RPM's show ok it means the tacho and connection back to the ignitor module seem ok, so either you have a pile of duff sensors or the only other bits its likely to be are the wiring back to the ignitor or the module itself
hope that helps
you need to understand, they are VERY sensitive, a fag paper would set it wrong.
keep it the propper way and do it superr gently, where abouts are you? profile doesnt state location.
I'm presuming they're all used ones?
I hate to say it but if they are then there is that small chance they could all be faulty, seeing as how old they are and the fact they are prone to be faulty.
My bike is on its 3rd one now.
You need to try one that you know for sure is good and working correctly, but that's obviously a bit of a tricky one unfortunately.
(03-03-15, 07:23 PM)Paulfzs link Wrote: you need to understand, they are VERY sensitive, a fag paper would set it wrong.
Really?! That sensitive? Thats crazy, I noticed they're all a bit rusty on the metal bits inside the holes, would that make any difference?
I'm in south Wales
(03-03-15, 07:25 PM)darrsi link Wrote: I'm presuming they're all used ones?
You need to try one that you know for sure is good and working correctly, but that's obviously a bit of a tricky one unfortunately. Hiya Darrsi!
Yea, they're all used ones.
Don't wanna believe they're all faulty otherwise it's just wasted money
Not much chance of getting one that I know is working I guess unless I bite the bullet and buy a new one, but at £165 don't really wanna do that.
andy chance that it could be that the idle/throttle cables/choke affecting it?
(03-03-15, 07:31 PM)jonest27 link Wrote: [quote author=darrsi link=topic=16142.msg185597#msg185597 date=1425407144]
possibly, when its at 5000 if you twist the throttle it goes to 10,000
Well I've just been out there for a good hour/ hours and half.
moved all 3 tps's a slowly as possible needle didnt move an inch, loosened throttle cable, turned down idle and tried again.
Running out of ideas here
maybe theyre all broken then :/
did you get off ebay?
did the seller say they work
One is the original off my bike, one is off Ebay (seller said it 's off a running bike) and the third on is from a bike breakers near me.
03-03-15, 09:57 PM
(This post was last modified: 03-03-15, 10:42 PM by darrsi.)
Turn the ignition on first (don't start it).
Then unplug the TPS.
Does the needle alternate between 0rpm and 3000rpm?
(03-03-15, 09:56 PM)jonest27 link Wrote: One is the original off my bike, one is off Ebay (seller said it 's off a running bike) and the third on is from a bike breakers near me.
May have been a running bike, but that's not to say they didn't realise their TPS could've been faulty.
Same with a breakers, if you tell them it doesn't work they just generally change things for you.
You may just be unlucky. :'(
(03-03-15, 09:59 PM)darrsi link Wrote: [quote author=jonest27 link=topic=16142.msg185626#msg185626 date=1425416182]
I guess I'll just have to at some point bite the bullet and get a new one or find someone with a working one.
If I got a new one and still cant get it to 5000, what would the next step be?
PMSL!
See, I'm not even sure that I care that much about the tps.
The bike runs, it has a few issues, but it'll still get me from A - B.
It's just the fact that I know it's not set up right, makes me want to sort it to know how it would run if it was sorted.
My biggest problem with the bike is a loud grinding/crunching noise that it gets intermittently when riding slowy that causes the bike to jerk (almost like the brakes are causing it) but I serviced the brakes recently and made sure that they weren't binding so I doubt thats it.
If anyone wants to have a stab a whats causing that then that'll help.
The loud grinding/ crunching noise is probably your chain. Clean it, inspect for tight spots, adjust it correctly and lube it. Also check your sprockets are in good condition.
